Prime Z590 Plus and Corsair Vengeance 3200Mhz settings
gomtuu
I see in the BIOS that I can up the DRAM frequency to 3200 from the default/auto setting of 2133. Do I need to modify any of the other DRAM settings to insure proper operation? The specs say tested at 1.35 volts, does that imply using that setting? What about timings. The CPU (Intel i711700K) is not overclocked.
McIrish
Can you just turn on XMP1? That should take care of all the memory timing and voltages on it's own. I don't believe you should have to do anything else.
Then again... I've had so many memory problems that I sure don't feel like an expert.
