Results 1 to 2 of 2
    New ROGer Array soulicro PC Specs
    soulicro PC Specs
    MotherboardAsus Z690 Maximus Extreme
    ProcessorIntel 12900k
    Memory (part number)1xCorsair CMT32GX5M2X6200C36(Ver 5.43.13)
    Graphics Card #1Asus ROG-STRIX-RTX3080TI-O12G-GAMING
    MonitorAcer Predator XB273UNV (UM.HX3EE.V05)
    Storage #11x2TB Samsung 980 Pro
    Storage #22x4TB Samsung 870 Evo
    CPU CoolerCorsair H170i Elite Capellix
    CaseCorsair 7000X RGB
    Power Supplybe Quiet! Dark Power Pro 12
    Keyboard Logi G915 Lightspeed TKL Clicky
    Mouse Logi G502 Lightspeed
    Mouse Pad Logi PowerPlay
    Headset/Speakers Sennheiser HDV820 > HD800S
    OS Windows 11
    Network RouterAsus DSL-AX82U
    Accessory #1 4xCorsair MP120 RGB
    Accessory #2 4xCorsair MP140 RGB
    Accessory #3 Noctua NT-H2
    Apr 2022
    1
    XMP Unstable / Z690 Extreme v1403 + QVL CMT32GX5M2X6200C36(Ver 5.43.13)
    Hi everyone,
    I'm trying to run 1 kit (bought 2 but yeah that's not going to happen apparently) of Corsair's QVL CMT32GX5M2X6200C36(Ver 5.43.13). It is unstable in both XMP I & II.
    After many attempts I've passed overnight passes of Karhu and HCI Memtest by clearing CMOS, leaving tuner setting at auto, disabling MCE, and manually entering XMP timings & voltages. Am currently in the middle of OCCT Memtest, but I figure with the coverage %s I achieved in Karhu and HCI Memtest I'm stable.
    Two questions:
    1) Why are neither of the two QVL kits able to run at either XMP I or II?
    1) Am I missing something in terms of performance by manually entering these settings instead of activating XMP?
    ROG Guru: White Belt Array Undertoker's Avatar
    Aug 2012
    107
    It seems to be a common problem on z690, certainly on Asus boards
    XMP profiles simply don’t work sadly and if they do are just not stable
    *I’m not sure if it’s down to memory or the bios, but my own 6000mhz g-skill z5 can only run at 5800
    There are four slots for ddr5 on the board for example, but I know in advance it won’t run all four sticks as many have tried and failed, so you are not alone
    I’m hoping Asus might improve this in future bios updates but I’m not holding my breath sadly, it might also improve as ddr5 memory matures.
    But it is wrong to advertise ddr5 running at frequencies it simply doesn’t run at*
    I9 12900KS @ 5.7Ghz
    ASUS ROG Strix RTX 3090 OC Edition
    ASUS ROG MAXIMUS Z690 EXTREME EATX Motherboard
    ASUS ROG PG35VQ @ 200mhz in 3440x1440
    Corsair Dominator Platinum RGB 32GB DDR5 CL36 @ 6200mhz
    Samsung 980 EVO Pro M.2 x 3 off
    NZXT Z63 Kraken AIO CPU Cooler
    NZXT H700i + Hue 2 (Pubg Edition) - Heavily modified
    ASUS ROG THOR 1200w PSU
    Corsair M65 RGB Mouse
    Corsair K95 RGB Keyboard
Tags for this Thread
