Repasted, CPU still throttling. Advice? Zephyrus M GU502GV (i7-9750h, RTX 2060)
Helgaiden
So my brother has been having an issue with his laptop that has gotten progressively worse. He finally had the last straw the other day so I sat down to go through testing rounds to figure it out and identified what appeared to be a GPU throttling issue. It will, seemingly at random, drop frequency of the GPU will drop to around 960mhz and the wattage of the 2060 will drop as well, down to around 40 watts. Obviously this tanks performance, but have tried many things to no avail. Verified it does this in both COD Warzone (2019, Black Ops Cold War, Cold War Zombies, and Vanguard), and Apex Legends so far. My brother also streams from his laptop and I had him install MSI afterburner and get the overlay configured so we could see whats happening when it behaves like this and we caught it live. Also id like to point out for OBS Studio that its been set in windows graphics settings to run in High Performance (so running on the 2060), and the preview window is disabled. Here's a clip of after it was running like normal, then throttled, then went back to normal and you can see the behavior i've described.
https://clips.twitch.tv/ObedientVainPlumageOSfrog-ahLMOppvm4kebI0U
Have tried: Clean reinstall of drivers, DDU and clean reinstall of drivers, windows 10 full reinstall, specifying any/all games and OBS Studio in the windows graphics settings to run in High Performance mode (so it runs on the 2060 instead of iGPU), setting GPU to "prefer maximum performance" in nvidia settings, setting Asus Armory Crate to max performance for the laptop, trying different game graphics settings, Hardware accelerated graphics scheduling on and off, set windows power plan to high performance, created custom max performance windows power plan.
Figured okay maybe there's thermal throttling, lets just repaste it. Had my brother come over and we cleaned out the fans and heatsinks and redid the thermal paste. I was unfamiliar with the thicker goop used on the VRAM and VRMs though (come to find out its K5 Pro). We put some Kingpin KPx I happened to have (spread manually) on the CPU and GPU and I had extra Arctic MX-4 that I put a thick dollop on the VRAMs and small dollop on the VRMs and everywhere else that had the thicker goop. I'm seeing that many people online used 1mm thermal pads instead for anything that wasn't the CPU or GPU, so I may have to revisit this. He ran through a short amount of testing and the original issue described above seems to have cleared up. No more GPU throttling dropouts. But GPU temps can still reach mid-80s and CPU mid-90s. Watching him test this live on his stream with the MSI afterburner overlay going, I saw the CPU going from around 4ghz down to 2.6ghz and bouncing around like that. Here is a clip.
https://www.twitch.tv/tzalman/clip/BlightedRelentlessMagpieYee-ESBJswGV0_TK-WGI
No framerate drops like from the first clip though. So it feels like 2 steps forward 1 step backwards. Thinking of ordering thermal pads for the VRM and VRAM chips and redoing this again. Any feedback on KPx on the CPU and GPU or should I try something else? Thanks in advance.
Helgaiden
Fantastic feedback. Got all the answers I was looking for. This is a fantastic place for questions. Thanks everyone.
BigJohnny
Have you checked battery health lately?
Right-click the Start button.
Select Windows PowerShell (Admin). ...
When the blue PowerShell window appears, type or paste powercfg /batteryreport /output "C:\battery-report. ...
Press Enter.
PowerShell will generate a battery report and save it to your computer.
Watch for where it saves it to, generally C:\ but make note anyway
Review battery health. If its shot then you need a new battery.
For highpowered laptops they cant take all the power from the brick. Playing hard core games or any other taxing process it will draw current from the battery. If this is on battery operation then thats all you will get. They need the juice! Thats why I hate when they put gaming and laptop on the same box. Will get you buy but for serious power all the time a desktop is the best route.
