Results 1 to 8 of 8
Thread: ROG STRIX G15 wifi problems
04-15-2022 07:54 AM #1
- Join Date
- Jan 2022
- Reputation
- 10
- Posts
- 5
So it's been 4 months of me putting up with the horrendous ping issues and constant disconnections in games and apps like discord with this MT7921 wifi card. I have tried about all the drivers in myasus and none have solved these problems. At this point I haven't played any online games due to this.
I'm thinking of buying the Ax210 intel card to replace it, is this card compatible? And is this replacement under warranty? Any help is kindly appreciated.
04-15-2022 09:10 AM #2
RedSector73 PC Specs Laptop (Model) FA506IU-AL130T x 2 Motherboard ROG CROSSHAIR VIII HERO (WI-FI) Processor AMD Ryzen 9 3900X 12-Core Processor Memory (part number) 4 x G.SKILL F4-3800C14D-16GTZN 14-16-16-36 Samsung B-Die Graphics Card #1 Gigabyte Aorus RTX 2080 Ti Xtreme WaterForce (GV-N208TAORUSX W-11GC) Sound Card Arctis DAC Monitor Asus ROG Swift PG348Q Storage #1 ADATA SX8200PNP 1TB Storage #2 2 x Samsung SSD 840 EVO 250GB CPU Cooler Coolermaster Liquid Pro Master 360 Case EVGA DG-87 Gunmetal Grey Gaming Case Power Supply EVGA SuperNOVA G2 750W Gold Power Keyboard Corsair K95 RGB Platinum Mouse Corsair Gaming Sabre RGB Gaming Mouse Headset ARCTIS Pro Wireless Mouse Pad Cooler Master MP750 RGB Cloth Gaming Mouse Pad Extra Large OS Windows 11 64bit Pro Network Router PfSence Intel i5-10210U 6 Port Accessory #1 TP-Link Gigabit 8&6 Port Switches
- Join Date
- Apr 2018
- Reputation
- 66
- Posts
- 1,358
Replace it with AX210 and you will be much more happy with your wifi connection
04-15-2022 05:15 PM #3
- Join Date
- Jan 2022
- Reputation
- 10
- Posts
- 5
04-16-2022 04:10 AM #4
- Join Date
- Apr 2018
- Reputation
- 66
- Posts
- 1,358
Intel AX210ONGW - NGFF (M.2) is what I used on my FA506IU - AL130T Laptop's (Tuff Laptop with AMD 4800h and GPU 1660ti), without checking suggest this is what you're after. Due diligence is on you and you should check your laptop M.2 wifi specification match your intended wifi card prior to purchase and/or watch on YouTube tear-down videos.
Any correct M.2 wifi card works in ASUS laptops there is no whitelist (like in dell or others) in the BIOS. Once you have right one, replaced the old wifi card with your new one and pop antenna's on, close her back up and can use Intel Driver assistant for latest drivers. Windows 11 and later versions of 10 have default drivers for the AX210.Last edited by RedSector73; 04-16-2022 at 04:27 AM.
04-20-2022 02:42 AM #5
- Join Date
- Jul 2018
- Reputation
- 11
- Posts
- 102
Hello
About warranty, please refer to service guide to disassemble laptop. Any damage caused by manual will violate warranty policy.
Service Guide:
https://dlcdnets.asus.com/pub/ASUS/G...ual_EM_WEB.pdf
Page 16 location:24
If you need RMA service in the future, please recovery hardware back to original setup before you send unit to repair center.
05-30-2022 07:59 AM #6
- Join Date
- Jan 2022
- Reputation
- 10
- Posts
- 5
Kudos to your reply and suggestion. So I wanted to give the card a second chance and decided to send in my laptop for a repair. As to my dismay, yes there are still connection issues. Better? Yes, but unacceptable because driving a car with mad engine hiccups is dangerous same with ONLINE comp games with connection issues. They swapped out the card for a new but the same mediatek model, even wiped out everything to factory settings (on my permission). Experienced my first blue screen as well after the repair.. So I see no other solution than to burn this knock-off card for an intel one. Wish me luck!
05-30-2022 12:44 PM #7
- Join Date
- Apr 2018
- Reputation
- 66
- Posts
- 1,358
07-03-2022 02:25 PM #8
- Join Date
- Jan 2022
- Reputation
- 10
- Posts
- 5
