Results 1 to 4 of 4
    New ROGer Array
    Apr 2022
    1
    ROG G713RC- No wifi network found after waking up from sleep mode
    Hi All,
    I recently bought this laptop but I am facing some issues. Whenever I close the lid of my laptop it goes in to the sleep mode and after 2-3 hour when i click the power button I see no wifi network until I restart my system.
    I have Wifi 6E driver installed - Mediatek WiFi 6E MT7922 (RZ616) 160Mhz Wireless Lan card.
    Can someone help me on this.
    Moderator Array
    Jul 2018
    11
    88
    Hello
    Sorry for late reply . Could you try to disable power saving mode in power option? Then try to duplicate again.
    New ROGer Array
    May 2022
    1
    Is there a solution to this?
    I am having the same problem with my G17 ROG Strix. Evry day i have to deactivate wifi driver and re enable to fix the wifi. But today it is all dead. tried all updates and also installed a older driver for the wifi without any luck. laptop is set to performance and plugged in
    Super Moderator Array
    Jan 2016
    182
    Quote Originally Posted by roaldolse View Post
    Hi, does it mean that the driver is updated by the device manager, but the problem still exists? If yes, it may be necessary to check the wireless network card. Please contact ASUS repair center in the country of your residence: https://www.asus.com/support/Service...All-Countries/. Sorry for any inconvenience it may be caused.
