Page 1 of 4 1 2 3 ... LastLast
Results 1 to 10 of 40
    New ROGer Array Jimbo93 PC Specs
    Jimbo93 PC Specs
    Laptop (Model)ABS Master Gaming PC
    MotherboardASUS Prime B560M-A AC
    ProcessorINTEL i5 10400F
    Memory (part number)G.SKILL F4-3200C16D-16GVKB x 2
    Graphics Card #1ASUS DUAL-RTX3060TI-O8G-V2
    Sound CardRealTek HD
    MonitorSAMSUNG 40" LCD
    Storage #1INTEL 660p NVMe SSD PEKNW512GB
    CPU CoolerTHERMALTAKE UX100 ARGB
    CaseTUF GAMING GT301
    Power SupplyASUS TUF GAMING BRONZE 650W
    Keyboard TUF GAMING K1
    Mouse TUF GAMING M3
    Headset/Speakers Cambridge Works PC
    OS Win 11 Pro 21H2 22000.652
    Accessory #1 Windows Feature Experience Pack 1000.22000.652.0
    Oct 2021
    82
    543
    Armoury Crate installation tips
    **Edited info about AI Suite 3 and Prefetch on 5-12-22 based on better info and results.
    ** New recommendation for a possible quick fix for many issues. I have 2 posts on the subject. Latest is in another thread here: https://rog.asus.com/forum/showthrea...ge2#post863163
    I first reported it later in this thread here: https://rog.asus.com/forum/showthrea...ge3#post862991
    Depending on the severity of your issues the rest of the info below is intended to get it running right but some of it is fairly involved.
    Hi I have an intel desktop system, the details are in my profile if you like to see them. I had my share of difficulties with AC 5.1.5, sorted it out finally.
    Problems I encountered
    1. It needed a fix for the keyboard, the developers took care of it after I sent my log
    2. Installation errors 504 and 101 that say restart and check internet connection
    3. RGB basic animation stuttering and the app saying it needed to turn on performance mode
    4. Updates resulting in poor performance like #3 above.
    *5. Using the uninstaller Armoury Crate - Support (asus.com) and installing again and running the installer 2 or 3 times after just rebooting (more than once) does not fix the issues you are experiencing.
    ** Definitely try just uninstalling with the tool and installing again and if you get a network error just restart and run the installer again.... Do that stuff before considering all the suggestions I have compiled. This list is a compilation of steps to cure whatever ails.
    IMPORTANT: These suggestions WILL NOT help if the AsusCertService.exe is not running properly on your system. Check it is running with Task manager-details tab or check windows event log Application log (there should be an Event 0, AsusCertService - "The operation completed successfully" event logged there immediately after system startup.
    1a. I recommend you turn off XMP memory overclock or cpu overclock during this process. If you have a usb flash drive just save your bios profile if this is a concern, and then you can reload it afterward.
    1b. Update your bios to the latest from Asus support page and/or set your bios to defaults. Note that you may need to check your TPM setting is correct after setting defaults.
    2. Update your hardware drivers (I recommend using MoKiChU's driver packs. https://rog.asus.com/forum/showthrea...ftware-Threads
    3. Use Driver store explorer to remove old drivers from you driver store, this app is shared by MoKiChU also in his driver threads.
    4. How to reinstall chipset drivers? MoKiChU has the answer for intel chipset here https://rog.asus.com/forum/showthrea...258#post856251
    *** THIS #5 IS NOT NECESSARY, I have a had good result (but no windows fan control) with just installing Armoury Crate, AND with installing AI Suite 3 after installing Armoury Crate. AI Suite 3 is good software I had it all working, but it does not allow to turn on virtualization and memory integrity for device security. I decided I need that more than windows fan control. 5.I used to think I need to install AI Suite first for the best system performance, not true anymore.
    Still good info here #6 especially if you want to strip AI Suite 3 out all the way.
    6. (EDITED twice) And more information on AI Suite 3.
    There is a cleaner app for completely removing it on your Asus support page. To get the best results:
    PAUSE windows updates FIRST. Just go to windows settings and windows updates and hit the pause button. You can come back and hit resume after this step 6 is complete.
    Uninstall A.C. with the uninstall tool, uninstall AI Suite 3 from windows settings-Apps, Remove Aura device drivers with device manager or with driver store explorer. For example I have 2 drivers that must be removed rogkb.inf and rogms.inf as seen with driver store explorer. Reboot then run the AI Sute 3 Cleaner. Run AI Sute 3 Cleaner a second time to make sure everything is removed.
    7. This doesn't take long to do. With A.C uninstalled and AI Suite 3 uninstalled use windows troubleshooter to make sure things are ok. Open the windows control panel-Troubleshooting. Run the following troubleshooters:
    a. Windows Update troubleshooter
    b. Search and Indexing troubleshooter - select the option files and folders are not showing
    c. Power troubleshooter
    d. System maintenance troubleshooter
    e. Windows store apps troubleshooter
    f. Restart the computer
    8. How is your network connection? If you have less than reliable network 100% of the time it is probably worth your time to investigate and correct.
    *Probably not necessary, probably, but I dont like having multiple identical entries in my firewall rules and I have reinstalled AC many times.
    9. Remove the few firewall entries that the A.C. uninstaller left. This is not difficult. Control Panel or search for Windows Defender Firewall. Open it, select Advanced settings, then select inbound rules. Remove the following entries should be near the top:
    a. ArmouryHtmlDebugger
    b. ArmourySocketServer
    c. FrameworkService
    10. Run the windows Disk Cleanup as Administrator and select temporary file categories
    11. Recompile .NET. Use Windows System Maintenance under Control Panel, Security and Maintenance, Start Maintenance. Or if you are in a hurry:
    a. Open 2 administrator command prompts
    b. In one of them execute these two commands
    i. CD C:\Windows\Microsoft.NET\Framework\v4.0.30319
    ii. ngen executequeueditems
    c. In the other command prompt execute these
    i. CD C:\Windows\Microsoft.NET\Framework64\v4.0.30319
    d. Go back to first command prompt and execute
    i. ngen update
    e. In the second command prompt execute
    i. ngen update
    *THIS IS NO LONGER CONSIDERED A BIG HELP. I have not had to resort to this in quite some time now, there are better solutions. 12. Just for the purposes of installing software, temporarily disable windows prefetching. This may make a big difference for you and is definitely worth trying. Use windows registry editor and go here
    HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Contro l\Session Manager\Memory Management\PrefetchParameters
    Note the current setting for the value called EnablePrefetcher. Change it to zero and restart the system. After all installation and updates of A.C. are done put it back to original setting and restart again.
    13. If you are still having trouble, uninstall everything again and follow these steps
    a. In an Adminstrator command prompt execute: DISM /ONLINE /CLEANUP-IMAGE /RESTOREHEALTH
    b. RESTART the computer.
    c. In an Adminstrator command prompt execute: SFC /SCANNOW
    d. In the same Admin command prompt execute: CHKDSK /X /F - answer yes and reboot.
    14. You can run the installer a second or even third time to get past the internet connection failure, without running the uninstaller again.
    15. There are also drivers installed by windows update for some (all?) Aura devices that can be removed just from device manager or by using driver store explorer. I refer to Keyboard drivers, mouse drivers etc. Edited: I think this is only necessary if you have also used AI Suite 3 at some time.
    Hope it helps someone. Feel free to post your suggestions or questions to this thread.
    Nate152 PC Specs
    MotherboardROG Strix Z690-F Gaming WiFi
    Processori7-12700KF
    Memory (part number)Kingston Fury Beast 16GB (2x8GB) 6000MT/s (KF560C40B)
    Graphics Card #1ROG Strix 3090 Ti LC OC
    Sound CardROG SupremeFX
    MonitorHP ZR30w
    Storage #1Seagate Firecuda 530 1TB
    CPU CoolerEK Quantum Velocity2
    CaseThermaltake Tower 900
    Power SupplyEVGA Supernova 1600 T2
    Keyboard ROG Falchion NX / Strix Flare II
    Mouse ROG Chakram X/Chakram Core/Spatha X
    Headset ROG Delta S Animate
    Mouse Pad Steelseries Prism XL + ROG Scabbard II
    OS Windows 11 Home
    Accessory #1 2x Swiftech Maelstrom X300 D5 V2
    Accessory #2 2x Hardware Labs SR2 560 MP radiators
    Accessory #3 Lamptron FC-5 V3 fan controller
    Nate152's Avatar
    Feb 2013
    398
    17,538
    Hey Jimbo,
    I reinstalled Armoury Crate the other day as I thought I messed up my mouse settings, turns out it was in game settings. Anyway, using the uninstall tool and reinstalling, the first time it failed and said to check my internet connection.
    I ran the installer a second time and it installed fine.
    Step 13 was all I needed to do.
    Jimbo93 PC Specs
    Mouse TUF GAMING M3
    Oct 2021
    82
    543
    Quote Originally Posted by Nate152 View Post
    Hey Jimbo,
    I reinstalled Armoury Crate the other day as I thought I messed up my mouse settings, turns out it was in game settings. Anyway, the first time it failed and said to check my internet connection.
    I just ran the installer again and it installed fine.
    Hi Nate,
    So I am nothing if not completely thorough with these posts for the cases that need it, lol. In my case I actually needed to do more to get to nirvana.
    Jimbo93 PC Specs
    Mouse TUF GAMING M3
    Oct 2021
    82
    543
    I had to add step 1a. Almost left it out.
    Jimbo93 PC Specs
    Mouse TUF GAMING M3
    Oct 2021
    82
    543
    One more detail relating to AI Suite 3. If you never used it then this does not apply.
    In order to get a full uninstallation of AsusFanControl and AXSP with the AI Suite 3 Cleaner, you will have to remove the device drivers that windows installed for the AURA sync devices. In other words, if you have a ROG mouse driver or any other Asus Aura device driver this needs to be uninstalled so that the Cleaner does not think Armoury Crate is still installed. Otherwise, the AsusFancontrolService and AXSP are not removed.
    Jimbo93 PC Specs
    Mouse TUF GAMING M3
    Oct 2021
    82
    543
    added a note about using the uninstaller and re-installing (standard ASUS recommended procedure) before using this thread.
  7. #7
    Jimbo93 PC Specs
    Mouse TUF GAMING M3
    Oct 2021
    82
    543
    Added: the need to pause windows updates when uninstalling AI Suite 3.
  8. #8
    Jimbo93 PC Specs
    Mouse TUF GAMING M3
    Oct 2021
    82
    543
    Polished up the OP, that should about do it.
  9. #9
    Jimbo93 PC Specs
    Mouse TUF GAMING M3
    Oct 2021
    82
    543
    If the steps in the OP do not help, I'd recommend running hardware diagnostics/memtest86 tests, if solid then reinstall windows.
  10. #10
    ROG Guru: White Belt Array Bushmaster78FS PC Specs
    MotherboardASUS® ROG™ STRIX Z370-G Gaming (Wi-Fi AC)
    ProcessorIntel® Core™ i7-8700K Processor
    Memory (part number)Corsair DOMINATOR® PLATINUM Special Edition Torque 32GB
    Graphics Card #1ASUS® ROG™ STRIX GeForce RTX™ 2070 OC Edition 8GB
    Sound CardASUS® ROG™ SupremeFX 8-Channel High-Definition Audio CODEC S1220A (on-board)
    MonitorASUS® ROG™ Swift PG349Q Ultra-wide G-SYNC™ Gaming Monitor
    Storage #1Corsair Force Series™ MP510 480GB M.2 SSD
    Storage #2Seagate BarraCuda 500GB Internal Solid-State Drive
    CPU CoolerCorsair Hydro Series™ H55 Quiet CPU Cooler
    CaseCorsair Carbide Series™ 200R Compact ATX Case
    Power SupplyCorsair TX-M Series™ TX750M — 750-Watt 80 Plus® Gold Certified PSU
    Keyboard ASUS® ROG™ STRIX Flare
    Mouse ASUS® ROG™ Spatha
    Mouse Pad ASUS® ROG™ Strix Edge Vertical Gaming Mousepad
    Headset/Speakers Sony® SRS-D5100 5.1 Multimedia and Gaming Speaker System
    OS Windows 11 Pro
    Network RouterNETGEAR® Nighthawk® 5-Stream AX4200 Wi-Fi 6 Router (RAX43)
    Accessory #1 Meta Oculus Rift VR
    Accessory #2 ASUS® BW-16D1HT Blu-ray Writer
    Accessory #3 Thermaltake® Commander FT Touchscreen Fan Controller
    Bushmaster78FS's Avatar
    Mar 2019
    43
    84
    Very nicely done mate, good instructions. I suffer from device page error 2005/2006 in AC so I used this method, at the very least it fixed an issue I was having with AISuite3, (GPU wasn't showing) and AC uninstalls and reinstalls fine (reinstall only in the second attempt, first attempts are always ending up with internet 101 error) AC is fully functional with the exception of getting into the device pages.
    One caveat though, deleting the .inf files of input devices from DriverStoreExplorer had some unexpected side effects. Reinstalling the Armoury Crate didn't reinstall these drivers back. So when all said and done with the Armoury Crate installation, I went and did a driver scan with both Windows Update and Driver Booster. The latter installed the drivers back on along with ROG Armoury II software.
