Results 1 to 8 of 8
    New ROGer Array
    Apr 2022
    5
    Z690 usb power when off
    I have a new Z690 motherboard that I just installed. I noticed that the USB ports still seem to be powered and the LEDs on the motherboard are still active when powered off. Is there any way to change this? I looked in the BIOS but couldn’t find an option.
    New ROGer Array RogScott PC Specs
    RogScott PC Specs
    MotherboardROG Strix Z690-E Gaming Wifi
    ProcessorIntel i9-12900K
    Memory (part number)32gb (2x16) Corsair Vengeance DDR5-4800
    Graphics Card #1EVGA 3090 FTW3 Ultra
    Monitor1) Dell U3014 2) Dell 2412M
    Storage #1Samsung 980 Pro 2tb nvme
    Storage #22x Samsung 980 Pro 1tb nvme
    CPU CoolerROG Ryujin II 360
    CaseCorsair 7000D Airflow
    Power SupplyEVGA 1200
    Keyboard Asus Strix Flair II Animate
    Mouse Logitech G502
    Headset Logitech G35
    Mouse Pad Perixx DX-2000
    Headset/Speakers Logitech 5.1
    OS Windows 11 Pro
    Network RouterAsus RT-AX86U
    Mar 2022
    20
    40
    Quote Originally Posted by AvonNova View Post
    Look under Advanced/Onboard Devices Configuration. There are options there to control USB power and LED when in sleep/off states.
    New ROGer Array
    Apr 2022
    5
    Quote Originally Posted by RogScott View Post
    Thanks! I don't know how I missed that.
    One weird thing is that the sleep, power off, etc. mode keeps getting reset. I changed it to Stealth Mode to turn off all LEDs, but it resets to Aura Only. Is something overriding this value, like Armoury Crate or Corsair iCUE?
    New ROGer Array
    Apr 2022
    5
    As it turns out, disabling the USB power doesn't work. I have it disabled, but my USB headphones are still getting power.
    ROG Guru: Orange Belt Array ahfoo's Avatar
    Jan 2020
    54
    389
    After disable the USB power, restart your system and turn it off. Unplug your power cord connected to your power supply for couple of minutes (10mins). Now connected your power cord to the power supply see if the problems occur again.
    New ROGer Array
    Apr 2022
    5
    As it happens, after I noticed that problem, I had my PC unplugged for a while yesterday to work on it. I tried it again today, and the problem still occurs. If I unplug the power for a while and then plug it back it with the main power on, the USB ports don't have power. But if I turn the PC fully on and then shutdown, the USB ports still have power.
    My BIOS version is 0604.
  7. #7
    ROG Enthusiast Array DragDay7 PC Specs
    DragDay7 PC Specs
    MotherboardAsus Z690-A PRIME DDR5
    ProcessorIntel i7-12700KF
    Memory (part number)Corsair 2x16GB 5600MHz CL36
    Graphics Card #1MSI 2080 Trio X
    MonitorHuawei MateView GT 34, Acer V247Y
    Storage #1Plextor PX-1TM10PGN
    CPU CoolerCustom EK Water Cooling
    CaseCorsair 5000D
    Power SupplyCorsair RM 750
    Keyboard SteelSeries APEX 7
    Mouse Logitech G403
    Headset Shure SRH 440
    Mouse Pad DreamMachines
    OS Windows 11
    Network RouterAsus RT-AC68U
    Accessory #1 Fanatec Porsche 911 GT3 RS V2
    Nov 2014
    52
    Try enabling ErP ready in bios - Advanced> APM.
  8. #8
    New ROGer Array
    Apr 2022
    5
    Enabling ErP worked. As I saved the change, it also showed that my sleep state was reverted to Stealth Mode. Thanks for the help. It's not a huge deal but there is no reason to waste the energy.
Tags for this Thread
