Results 1 to 9 of 9
05-01-2022 12:06 PM #1
- Join Date
- Apr 2021
- Reputation
- 10
- Posts
- 5
B550 I - BSOD irql not less or equal
So I've had this build for about a year. Win 10, with an AMD 4750G but it was upgraded to a AMD RX 6600 about six months ago. Has 32gigs of Team Group DDR4. I can't remember if it's on the QVL, but I try and make sure my builds all have the correct memory.
I'm getting BSODs about twice a day. Seems really random, just watching a youtube video or listening to music. Most common report is irql not less or equal. I've done a SFC and all the the other things you can find in a google search on that error message. I have had other BSODs with different error msgs. but that's the most common. Each time I run SFC after I get an unexpected shutdown, it seems to find corrupted files that it fixes.
I'm starting to get annoyed and think I might try and install Win 11. I like 10 a lot better though.
Anyone else getting BSOD on B550 I boards?
05-01-2022 01:11 PM #2
Nate152 PC Specs Motherboard ROG Maximus IX Code Processor i7-7700k 5.2GHz Delidded Memory (part number) 16GB G.Skill Trident Z - 3600MHz 16-16-16-36-2T Graphics Card #1 Titan Xp - EKFC waterblock Sound Card ROG SupremeFX 2015 Monitor HP ZR30w Storage #1 Toshiba VX500 256GB CPU Cooler Swiftech Apogee GTZ Case Thermaltake Armor+ VH6000 Power Supply PCP&C Turbo Cool 1200w Keyboard ROG Falchion NX / Strix Flare II Mouse ROG Chakram X/Chakram Core/Spatha X Headset ROG Delta S Animate Mouse Pad Steelseries Prism XL + ROG Scabbard II OS Windows 11 Home Accessory #1 Asus optical drive Accessory #2 Koolance ERM-2K3U
- Join Date
- Feb 2013
- Reputation
- 375
- Posts
- 17,236
Hi bpm990d
I've gotten the "irq not less or equal" BSOD when overclocking my memory.
I suspect memory instability.
You can try loosening the timings, lowering the frequency or leave as is and raise some voltages.
Dram voltage - 1.40v
SOC voltage - 1.20v Maximum
If raising voltages, there will be a slight increase in Dimm module temp and cpu temp.
05-02-2022 10:42 AM #3
- Join Date
- Apr 2021
- Reputation
- 10
- Posts
- 5
Hey thanks for the reply, I'll have to give it a try. My memory is DDR 3600 with 18-22-22-42 timings and it's running at 3600ghz.
I have a back up of my Win10 install, so I decided to do a clean install of Win 11 yesterday to see if that would solve my issue. Yup, BSOD on that OS as well. Once I post this, I'll go into my UEFI and play around.
Thanks again, B
05-02-2022 05:43 PM #4
J Bish PC Specs Motherboard Crosshair VIII Formula Processor AMD Ryzen 5950x Memory (part number) 64gb KHX3600C18D4 Graphics Card #1 XFX 5600XT Graphics Card #2 XFX 5600XT Sound Card Creative A-E5 Monitor ProArt PA329CV Storage #1 WD SN850 512gb Storage #2 WD Black Sata 6gb OS Windows 11 (All Current)
- Join Date
- Apr 2022
- Reputation
- 10
- Posts
- 29
05-04-2022 12:06 AM #5
- Join Date
- Apr 2021
- Reputation
- 10
- Posts
- 5
05-04-2022 12:33 AM #6
- Join Date
- Apr 2021
- Reputation
- 10
- Posts
- 5
OMG, I can't win. I went for 24 hrs without a problem and then when I post that I hope I don't jinx myself, I get a KMODE EXCEPTION NOT HANDLED BSOD within 5 minutes. Grrrr........
Never had a problem with any of my other AUSU boards. I don't think it's my memory, since I have run a memory diagnostic and it found no errors. I can't remember which one it was, but it ran on bootup.
I have run SFC several time and more often than most it finds errors and repairs them. A couple of times the reference file was borked and I needed to re-download it.
B
05-13-2022 04:57 PM #7
- Join Date
- Feb 2013
- Reputation
- 375
- Posts
- 17,236
I've got this one too.
The KMODE EXCEPTION NOT HANDLED can be a memory related error but can also be a corrupted/outdated driver.
You could try SOC voltage at 1.15v - 1.20v Maximum. If you still get blue screens, reset to defaults and see how it goes from there for a while.
If you get blue screens at default settings, take note if it gives any driver or device indication.
Or do a fresh windows reinstall.
05-16-2022 06:15 AM #8
Hello,
Remove any CPU overclocking such as PBO
Run Karhu Ramtest for 1000-1500% and check for errors at XMP settings.
06-20-2022 08:53 PM #9
- Join Date
- Apr 2022
- Reputation
- 10
- Posts
- 29
