Fan control software for Zenith II Extreme
mboogie
Can anyone recommend a good fan control software alternative to AI Suite 3 (which I want to uninstall). I tried SpeedFan 4.52 but it can't find any fans on this system (Configure/Advanced/Chip-dropdown shows only storage devices and gfx card, no motherboard chip option. Thanks.
(p.s. mods, I can't post messages in the 'correct' forum page !!!)
gontch
The best fan control software that I coud find is Argus Monitor.
It supports ASUS Fan Extension Card as well.
It is very stable and can control GPU fans or water-cooling loop with avg temperatures between CPU/GPU.
Thank you for this help, much appreciated. I checked out Argus Monitor and it's webpage suggested it does everything needed, including controlling fans via the Asus extension board. I uninstalled AISuite 3 and Armoury Crate (a fairly laborious process to do...needed help via Google), then installed Argus Monitor. Unfortunately, there appear to be issues with this motherboard and Argus Monitor...
Under Argus Monitor's Settings/Mainboard/Fans Configuration, I see that if I select 'Nuvoton NCT6798' for the 'Source', only 7 controllable fans appear (others such as extension fans and water pump are missing). If I select 'Asus Service' for the 'source', I see the missing fans I want to control unfortunately, Argus Monitor does not allow me to control these fans, saying this source is read only.
--> 1. Can I ask Asus to tell me if they've locked out 3rd party fan controllers from working here? - this seems to be the case! (I'm also awaiting an email reply from Argus itself.
--> 2. I'm thinking this is an issue of other Asus motherboards too?
Mappi75
For what i understand in the Argus Monitor FAQ's
you only can monitor the extension card and NOT controlling it.
