Results 1 to 5 of 5
    ROG Junior Member Array DoomerDGR8 PC Specs
    DoomerDGR8 PC Specs
    MotherboardZ87-DELUXE/QUAD
    ProcessorIntel® Core™ i7-4770K
    Memory (part number)Corsair Vengeance® 16GB DDR3 1600MHz (CMZ16GX3M2A1600C10)
    Graphics Card #1AORUS GeForce® GTX 1080 Ti Xtreme Edition 11G GV-N108TAORUS X-11GD
    MonitorKOGAN 34" WQHD IPS Ultrawide 144HZ USB-C FreeeSync HDR Gaming Monitor (3440x1440) - KAMN34XQUCLA x 2
    Storage #1Samsung SSD 840 x 1
    Storage #2SanDisk SDSSDH3 500Gx2 + SanDisk SSD PLUS 480GBx2
    CPU CoolerCoolerMaster
    CaseNZXT Phantom 630
    Power SupplySilverStone Strider Essential 700 Watt
    Keyboard Logitech G910
    Mouse Logitech G502
    Headset Logitech G935
    OS Windows 10 Pro 21H2.10944.1682
    Network RouterD-Link DIR-869
    Accessory #1 Logitech C922
    Apr 2012
    3
    Z87-DELUXE/QUAD: VGA_LED always RED/ON
    I'm using a dated build but recently snagged a AORUS GeForce® GTX 1080 Ti Xtreme Edition 11G GV-N108TAORUS X-11GD. I'm running this board with an Intel® Core™ i7-4770K and a kit of Corsair Vengeance® 16GB DDR3 1600MHz (CMZ16GX3M2A1600C10).
    Ever since I got the 1080, I notice the VGA_LED stays RED:
    DoomerDGR8 PC Specs
    Mouse Logitech G502
    Apr 2012
    3
    Please DO NOT mind the dust cake layer. I'll clean it but this issue is present even after a thorough clean up I did 6 months ago.
    Nate152 PC Specs
    MotherboardROG Strix Z690-F Gaming WiFi
    Processori7-12700KF
    Memory (part number)Kingston Fury Beast 16GB (2x8GB) 6000MT/s (KF560C40B)
    Graphics Card #1ROG Strix 3090 Ti LC OC
    Sound CardSupremeFX
    MonitorHP ZR30w
    Storage #1Seagate Firecuda 530 1TB
    CPU CoolerEK Quantum Velocity2
    CaseThermaltake Tower 900
    Power SupplyEVGA Supernova 1600 T2
    Keyboard ROG Falchion NX / Strix Flare II
    Mouse ROG Chakram X/Chakram Core/Spatha X
    Headset ROG Delta S Animate
    Mouse Pad Steelseries Prism XL + ROG Scabbard II
    OS Windows 11 Home
    Accessory #1 2x Swiftech Maelstrom X300 D5 V2
    Accessory #2 2x Hardware Labs SR2 560 MP radiators
    Accessory #3 Lamptron FC-5 V3 fan controller
    Nate152's Avatar
    Feb 2013
    386
    17,411
    Hi DoomerDGR8
    Is everything working ok other than the vga light being on?
    Have you updated to the latest bios for your motherboard?
    Are you using two separate pci-e cables?
    Try with different monitor cables, DVI, HDMI, Display Port.
    DoomerDGR8 PC Specs
    Mouse Logitech G502
    Apr 2012
    3
    Q: Is everything working ok other than the vga light being on?
    A: Yes. All works except there is a situation (very rare) where machine hangs and faults out to BSoD
    Q: Have you updated to the latest bios for your motherboard?
    A: Many years ago. The latest official BIOS was flashed.
    Q: Are you using two separate pci-e cables?
    A: Yes. The PSU has two rails and I'm using plug #1 of each rail
    Q: Try with different monitor cables, DVI, HDMI, Display Port.
    A: I have 2 x DP + 1 DVI monitors hooked up
    Bonus: Sometimes, while playing graphics heavy games with certain scenes or heavy actions, I do see a white light flash off the area of the GFX near the power connectors. This is what prompted me to use two PCIe rails instead of a single and I think I haven't seen that POWER_LED go off since.
    Nate152 PC Specs
    Processori7-12700KF
    Sound CardSupremeFX
    MonitorHP ZR30w
    OS Windows 11 Home
    Nate152's Avatar
    Feb 2013
    386
    17,411
    Ok so,
    Looking at the specs of your psu, it says it has three 6-pin pcie cables and one 6+2-pin pcie cables, which = one 8-pin pcie power cable.
    I'll post it to be sure.
    https://www.newegg.com/silverstone-s...PDsP4DfL33TAxQ
    The Aorus 1080 ti extreme has two 8-pin pcie power connecters.
Tags for this Thread
