Results 1 to 3 of 3
05-15-2022 01:26 PM #1
rm43uk PC Specs Motherboard ROG STRIX Z690-F Processor Intel i7 12700k Memory (part number) CMK32GX5M2A4800C40 Graphics Card #1 NVIDIA GEFORCE RTX 3070 TI Case HAF X 942
- Join Date
- May 2022
- Reputation
- 10
- Posts
- 4
LED PROBLEMS ON ARGB and RGB FANS
Hi Community
I hooked a Cooler Master Masterfan Mf200R ARGB directly onto the ARGB port on My ROG STRIX Z690-F board yesterday The fan does power and light up but its stuck on light blue and have noticed the 3 pin adaptor is very loose too, am i doing this right or do i need a controller, Aurasync, creator and armourycrate are not doing anything, i have uninstalled reinstalled etc
This Aura sync is turning into a nightmare for me, the fan i had before a Bitfenix Spectre pro rgb which i had hooked up to the 4 pin Rgb slot via the supplied aura sync cable did work but wouldnt show red or green i would instead get pink and turqouise, when i selected yellow i got white, so got the Coolermaster one in the hope that would replace my existing problem
Seriously starting to lose it with these fans now and am hoping you guys can assist me with this
Thanks in advance
RM
05-17-2022 06:59 PM #2
MJr418 PC Specs Motherboard Prime x570-p Processor AMD Ryzen 5 3600 Memory (part number) 4 x 8gb Vengeance pro RGB Graphics Card #1 KO GeForce RTX 3070 V2 OC Edition Monitor Dual LG 24" Storage #1 Samsung 850 Evo Storage #2 Samsung 860 Evo CPU Cooler CM 212 Hyper BE RGB Case not branded case Power Supply Thermaltake Toughpower Keyboard Logitech G815 Mouse Logitech G600 Headset Logitech G pro Headset/Speakers Logitech Stereo Speakers OS Windows 10 pro Accessory #1 aRGB Fans Accessory #2 aRGB Strip
- Join Date
- Oct 2020
- Reputation
- 10
- Posts
- 20
Maybe faulty Fan, only way to know by trying another argb fan/strip-light, as for rgb fan you may try calibrate it may help and fix it
I don't defend Asus and they aren't near perfect but truth need to to be told, corsair is expensive and some of their lighting is bad, my argb corsair rams white is pinkish.
05-22-2022 09:48 AM #3
- Join Date
- May 2022
- Reputation
- 10
- Posts
- 4
Hello
It was a faulty CM fan, the replacement works perfectly
Thankyou for the reply
RM
