Results 1 to 10 of 17
06-06-2022 09:46 AM #1
ChroMiuM Deejay PC Specs Motherboard Z270F Processor I7700K Memory (part number) CMR16GX4M2C3466C16 Graphics Card #1 STRIX-GTX1070-O8G-GAMING 8GB GDDR5 Storage #1 M.2 Patriot Hellfire M2 Storage #2 Crucial CT525MX3001SSD1 CPU Cooler Corsair H115i Case NZXT Noctis 450 Power Supply RM 750X Keyboard Microsoft SideWinder X4 Keyboard Mouse Logicool G502 OS Win10
- Join Date
- Jul 2017
- Reputation
- 10
- Posts
- 27
Warranty problems! RTX 2080 SUPER Strix
Hellow guyz! Im having some issues with my 2080s, i called asus and they said that my warranty its 1 year, wtf? Into the videocard box it CLEAR says 3 years , how to deal with it?
06-06-2022 01:09 PM #2
420Assassin PC Specs Motherboard Asus ROG STRIX B550-F (AM4) Processor Ryzen 5 5600X Memory (part number) CMW32GX4M2Z3600C18 x2 Graphics Card #1 KO-RTX3070-O8G-V2-GAMING Monitor VG248QE /2nd display VH238 Storage #1 Samsung SSD 980 PRO 1TB Storage #2 Samsung SSD 840 EVO 1TB CPU Cooler Corsair iCUE H115i Elite 280mm Case Antec P120 Crystal Power Supply Seasonic Prime Ultra 750 Titanium Keyboard Asus TUF K3 Mouse Logitech G502 Hero Headset Turtle Beach DX11 Headset/Speakers Logitech Z623 w/Subwoofer OS Win10 Pro Network Router GT-AC5300
- Join Date
- May 2012
- Reputation
- 10
- Posts
- 12
Check warranty status here..
https://www.asus.com/us/support/warr...tatus-inquiry/
Asus is usually really good about warranty
06-06-2022 10:08 PM #3
- Join Date
- Jul 2017
- Reputation
- 10
- Posts
- 27
I tried that already, 4 or 5 days ago,when i placed my SN on that webpage,it said that my card still have Warranty,now after talk with asus support ,if i place my SN,it says to contact Asus to know about my warranty,so they disabled it for me!!!
Im currently at work in Japan,and i bough that card here, when i got that gpu,i was secure becouse in the box it says 3 Years Limited Warranty, and theres another Local warranty managed by Tekwind, but the warranty from tekwind its only 1 year....so i tried to activate the second warranty direct from asus but they refuses to help me,they said that i have only a Tekwind warranty,and i dont have Asus 3 years warranty ...
Also that tekwind its kinda scam, they asked me to send my gpu to repair,and will be charged same amount of money of a new one !
its not my fault, the gpu started have problems 2 weeks ago while im playing games,it goes to 80 or 81c really quick, and looks like gpu tweak dont shows me the real temps after 81c idk, so when playing games its all the time 81c and some times the fans runs arround 3000rpm for a few seconds then come back to normal arround 1500 rpm, i think it can be problems with sensors or thermal paste,im not sure.... i tried fresh windows install,updated gpu tweak,tried silent and gaming gpu tweak default settings,,tried new and old nvidia drivers,tried place the gpu into another computer and the issue continue,the only way to keep my temps like before is ,setting Power Target 65% in GpuTweak,losing alot of performance... its really annoying when its starts runs at 3000rpm for 1 - 3 seconds all the time....its very loud..
i bought this card in November / 2019....
have any one here with similar issue?Have you guys managed what to do?
06-06-2022 10:19 PM #4
- Join Date
- Jul 2017
- Reputation
- 10
- Posts
- 27
06-07-2022 12:15 AM #5
Nate152 PC Specs Motherboard ROG Strix Z690-F Gaming WiFi Processor i7-12700KF Memory (part number) Kingston Fury Beast 16GB (2x8GB) 6000MT/s (KF560C40B) Graphics Card #1 ROG Strix 3090 Ti LC OC Sound Card ROG SupremeFX Monitor HP ZR30w Storage #1 Seagate Firecuda 530 1TB CPU Cooler EK Quantum Velocity2 Case Thermaltake Tower 900 Power Supply EVGA Supernova 1600 T2 Keyboard ROG Falchion NX / Strix Flare II Mouse ROG Chakram X/Chakram Core/Spatha X Headset ROG Delta S Animate Mouse Pad Steelseries Prism XL + ROG Scabbard II OS Windows 11 Home Accessory #1 2x Swiftech Maelstrom X300 D5 V2 Accessory #2 2x Hardware Labs SR2 560 MP radiators Accessory #3 Lamptron FC-5 V3 fan controller
- Join Date
- Feb 2013
- Reputation
- 386
- Posts
- 17,420
Hi Chromium Deejay
So, your gpu works but you're having temp issues. 80-81c is warm but is within specs, according to Nvidia up to 89c is fine for the RTX 2080 Super.
What I would try is setting a fan curve in GPU tweak III.Last edited by Nate152; 06-07-2022 at 02:24 AM.
06-07-2022 03:41 AM #6
- Join Date
- Jul 2017
- Reputation
- 10
- Posts
- 27
the problem is,looks like the temps are locked at max 81c for some reason or the sensors dont shows me the real temps,and the fans get crazy running at 3000rpm for a few seconds doing alot of noise,then return to normal rpm, something similar at this guyz here, https://rog.asus.com/forum/showthrea...n-fan-behavior
also,yes,the gpu temps are too righ, and videocard its very clean..no dust at allLast edited by ChroMiuM Deejay; 06-07-2022 at 03:44 AM.
06-07-2022 03:49 AM #7
- Join Date
- Apr 2019
- Reputation
- 66
- Posts
- 1,553
Hi ChroMiuM Deejay,
May I have the serial number and invoice via pm to check the warranty?
06-07-2022 07:57 AM #8
- Join Date
- Jul 2017
- Reputation
- 10
- Posts
- 27
Hi,ok ..!!
06-07-2022 08:16 AM #9
- Join Date
- Jul 2017
- Reputation
- 10
- Posts
- 27
Pm Sent...
06-08-2022 02:41 AM #10
- Join Date
- Apr 2019
- Reputation
- 66
- Posts
- 1,553
Hi ChroMiuM,
After checked with our local team, repair service is provided by our distributors in Japan and and all terms and conditions must comply with the distributor's regulations.
Sorry for any inconvenience caused.
