z490e ethernet issues/ new ethernet question
g_patryk
Hey all,
Been dealing with this junk ethernet on 2 computers, Its been working Ok until i started doing backups using synology.
Long story short the built in Intel(R) Ethernet Controller (2) I225-V. its fully updated with the firmware as well.
Symptoms: when a backup is initiated the ethernet becomes unresponsive, cannot disable from device manager, cannot reboot pc unless i flip the power switch.
I worked with synology support extensively running through logs, fixes, adjustments and the conclusion was that it only happens on this ethernet on 2 separate computers. Wifi works fine
Resolution:
I installed a tplink TG-3468 and I no longer have issues However why is it showing as realtek pcie gbe family controller instead of the TP link device? Not sure if its a huge deal.
Tried to contact support but apparently if you choose US the technical support function disappears (real nice asus)
g_patryk
ended up installing the latest windows drivers from
https://www.realtek.com/en/component/zoo/category/network-interface-controllers-10-100-1000m-gigabit...
updated everything to 2022 drivers
