06-12-2022 07:18 PM - last edited on 03-06-2024 10:14 PM by ROGBot
06-13-2022 03:38 PM
07-08-2022 07:06 AM
Vaporwave wrote:
So, one of the LEDs failed partially, as it no longer works with blue or purple colors. Instead, it turns green when it's supposed to be blue and red when it's supposed to be purple. I've been thinking of replacing it eventually, but I'm not sure about the LED size. From what I understand, this keyboard has 3mm RGB LEDs with 3 pins. Does anyone know if this is correct?
07-08-2022 07:24 AM
07-08-2022 08:42 AM
10-01-2022 06:59 AM
Murph_9000 wrote:
I don't have an answer to the original question, just an observation. Beware the different versions of the Strix Scope. At a minimum, there are MX, NX, and RX keyswitches. In particular, the RX may use different LEDs because it's a quite different design of keyswitch (optical, with no centre post).
07-12-2022 10:55 AM
bobobev@mail.ru wrote:
exactly the same problem, did you manage to solve it?
07-09-2022 09:33 AM
