06-14-2022 12:32 AM
06-14-2022 01:49 AM
DragDay7 wrote:
What's your bios version?
Also your cooler has PWM fan and you should leave its mode like that.
06-14-2022 02:26 AM
06-14-2022 04:07 AM
06-14-2022 05:14 AM
plee5509 wrote:
This has to be a bug in the ASUS Bios and for CPU fans they've got a formula error.
06-14-2022 05:31 AM
DragDay7 wrote:
I'm not that sure, if that'd be the case you wouldn't be the only one with that issue.
Have you tried clearing CMOS by unplugging power cord and shorting CLRTC pins? They're at the bottom of your motherboard.
Other than that and reflashing bios I have no idea and you should wait for someone smarter. Hell, even if I try to google your issue there is none.
06-14-2022 05:35 AM
plee5509 wrote:
Yes tried clearing the CMOS and BIOS has been re-flashed. Maybe others are having the issue, they just don't realise they are, initially I had no idea I had this behaviour going on as all the fans were all ramping up with the CPU by default so if the CPU fan was slowing down you wouldn't have known it, it was only when I was taming things and monitoring temperatures that I realised this was happening. Also if using the Asus software to control the fans it might well be that takes over from the BIOS and so it works okay. I'm certainly not installing that Asus software just to find if that is the case, it's terrible and I had to reinstall Windows 11 after an initial play about with it to get rid of it!
06-14-2022 05:56 AM
ahfoo wrote:
If you made full use of bios QFAN curve, you dont need to install asus or third party fans control.
06-14-2022 05:57 AM
