Results 1 to 5 of 5
    New ROGer Array
    May 2022
    4
    Exclamation TUF Gaming Z590-PLUS WIFI PCI-E Link Speed
    I have this MOBO with an ASRock OC Formula RX6900XT and when I open GPU-Z up it says I'm only at x16@1.1 I've done the built-in render test to see if it changes and it does not. I've also ran a GPU benchmark and that doesn't change it either. I also looked in the AMD software and it also says x16@1.1 I honestly don't know how something can be 1.1 never even heard of that before. I also have my bios updated to the latest one which is 1601. I have the link speed in the BIOS set on Gen3 but nothing I do seems to change it. Does anyone have any idea of what could be causing this issue and how to fix it?? Thanks in advance for any replies and help. Here's a screen shot.
    https://ibb.co/L6SPYNF
    THOMAS
    Moderator Array world PC Specs
    world PC Specs
    MotherboardASUS PRIME X470-PRO
    ProcessorRyzen 3600x
    Graphics Card #1ASUS ROG Strix 1080 ti
    Sound CardAune T1 DAC
    CPU CoolerThermaltake Water 2.0
    CaseJonsbo U4
    Power SupplyCooler Master V1200
    Mouse Asus ROG Chakram X
    Headset Sennheiser HD598
    Feb 2017
    47
    78
    Just to cover some of the bases:
    Do you have anything overclocked? If you do, see if you get the same issue with overclocks disabled (both GPU and CPU)
    Is your GPU-Z version the latest one?
    Is your AMD driver the latest version?
    New ROGer Array
    May 2022
    4
    Quote Originally Posted by world View Post
    I've tried it with and without an OC on the CPU and GPU no change. Yes GPU-Z is the latest version. 22.5.2 Is the driver I'm using according to the AMD software it's up to date.
    THOMAS
    New ROGer Array
    May 2022
    4
    I also went ahead with optimized defaults in the BIOS just to see if it would help, but it didn't.
    THOMAS
    New ROGer Array
    May 2022
    4
    Anyone else have any idea of what could be happening with this??
    THOMAS
