Results 1 to 6 of 6
Thread: plz help!!!
    New ROGer Array
    Jun 2022
    3
    plz help!!!
    I have a full rog system and randomly gaming or just idle the keyboard turns off and the computer freezes the only way i can get it to work again is to unplug it from the wall because the reset and power button don't work either.
    i have upgraded all drivers done stress test on everything and still happening it's the most frustrating thing ever
    TeamROG Moderator Array xeromist PC Specs
    xeromist PC Specs
    Laptop (Model)Intel NUC laptop LAPQC71D
    MotherboardROG Crosshair VIII Dark Hero
    ProcessorAMD 5800X
    Memory (part number)32GB G.Skill Ripjaws V 3600
    Graphics Card #1ROG Strix RTX3090Ti
    Sound CardSound Blaster Z
    MonitorAORUS FV43U
    Storage #1Samsung 970 Pro 512GB
    CPU CoolerCustom loop
    CaseBeQuiet Dark Base Pro 900 V2
    Power SupplyCorsair HX1000
    Keyboard ROG Strix Flare II Animate
    Mouse ROG Chakram X
    Headset Steelseries Arctis Pro Wireless
    Mouse Pad ROG Scabbard
    Headset/Speakers Logitech z906 5.1
    Network RouterpfSense/OPNsense
    xeromist's Avatar
    Jul 2010
    411
    8,487
    This could happen due to an overclock or memory issue. How often does it happen and do you have the BIOS at stock with XMP disabled?
    In the past I've also had issues with stability due to GPU issues. If there is any way you can test with just integrated graphics or if you have an old GPU that would help eliminate another variable.
    * Support disease research with Folding@Home *
    < < < Click the drop-down above my avatar for my PC specs!
    Administrator Array Silent Scone@ROG's Avatar
    Mar 2016
    233
    2,708
    Hello,
    Please remove any overclocking from the systems including memory XMP profile and report back if the problem is still present.
    New ROGer Array
    Jun 2022
    3
    Thanks
    I removed all overclocking bios is back to default i am going to change the gpu im running a strix 3090 oc edition but i will change it all drivers are up to date as well and everything is new i am thinking maybe the power supply i have a thor 1200 from asus it happens often at least once a day sometimes processor speeds drop to 0.5 hz so the computer is mad slowÂ*
    New ROGer Array
    Jun 2022
    3
    Do you recommend disabling xmp? Or not
    Mar 2016
    233
    2,708
    Quote Originally Posted by mariosevilla View Post
    Yes, XMP is overclocking so disabling this is troubleshooting 101
