Results 1 to 3 of 3
    Nate152 PC Specs
    MotherboardROG Strix Z690-F Gaming WiFi
    Processori7-12700KF
    Memory (part number)Kingston Fury Beast 16GB (2x8GB) 6000MT/s (KF560C40B)
    Graphics Card #1ROG Strix 3090 Ti LC OC
    Sound CardROG SupremeFX
    MonitorHP ZR30w
    Storage #1Seagate Firecuda 530 1TB
    CPU CoolerEK Quantum Velocity2
    CaseThermaltake Tower 900
    Power SupplyEVGA Supernova 1600 T2
    Keyboard ROG Falchion NX / Strix Flare II
    Mouse ROG Chakram X/Chakram Core/Spatha X
    Headset ROG Delta S Animate
    Mouse Pad Steelseries Prism XL + ROG Scabbard II
    OS Windows 11 Home
    Accessory #1 2x Swiftech Maelstrom X300 D5 V2
    Accessory #2 2x Hardware Labs SR2 560 MP radiators
    Accessory #3 Lamptron FC-5 V3 fan controller
    Nate152's Avatar
    Feb 2013
    386
    17,420
    UV LED Strip lights
    Hello,
    Does anyone have experience with or know of a good brand of UV LED strips?
    I'm doing a build in the Thermaltake Tower 900, the UV LED lights I'm currently looking at are the Darkside Connect G2 Pro UV LED light strips. Trouble is, they're only 12" long and two 12" strips won't be enough.
    I chose these because you can connect a 3-pin fan cable and control the brightness with a fan controller.
    https://www.dazmode.com/shop/lights/...rip-uv-g2-pro/
    Would anyone know of something similar but longer than 12"?
    Nate152 PC Specs
    Processori7-12700KF
    MonitorHP ZR30w
    OS Windows 11 Home
    Nate152's Avatar
    Feb 2013
    386
    17,420
    I found what I was looking for.
    Darkside DUAL CONNECT Extension – 12″ (30cm) Dual-Ended LED Strip – UV PRO (DS-1155)
    ROG Junior Member Array
    Feb 2017
    1
    Why it's UV, you can install RGB, white or RGBIC LED Strips inside. just curious.
