Results 1 to 3 of 3
06-30-2022 03:24 PM #1
- Join Date
- Jun 2022
- Reputation
- 10
- Posts
- 10
Axe16000 and ASUS Z690-F mobo wake on lan issue
Hey all, not sure if I need to post this here or in motherboards so I’m doing both, here is my issue:
When I only connect using Wi-Fi, I can wake the computer using a magic packet sent from a mobile app or from my axe16000 router. When I connect using Ethernet, nothing. No lights on the nic when the pc sleeps, so I’m guessing maybe the card is fully powered down (or maybe the lights are just off?) and therefore isn’t getting any packets, but I tried every possible options of APM bios settings, NIC advance settings, windows 11 power modes, updating drivers, removing and re-adding the nic, etc and nothing, it’s dead when the pc sleeps. *I read some places you need to port forward or put the PC in a DMZ, but if Wi-Fi WOL works I assume it’s not router but can’t rule it out. *
Has anyone else encountered this and fixed it?
Thanks!
06-30-2022 03:52 PM #2
Saltgrass PC Specs Motherboard Maximus XIII Hero Processor i9 11900K Graphics Card #1 EVGA RTX 3090 FTW Sound Card On Board Monitor Dell AW3420DW Storage #1 Samsung 980 Pro 2 TB Storage #2 Samsung 860 Pro 1 TB CPU Cooler Cooler Master Hyper 212X Case Cooler Master Power Supply Antec HCP Platinum 1000 Keyboard ASUS Strix Flare Mouse ASUS Chakram Headset/Speakers Logitech wired 5.1 OS Win 10 Pro Network Router ROG Rapture GT-AX11000/AXE11000 Accessory #1 VR Headset Accessory #2 Saitek X52
- Join Date
- Jan 2014
- Reputation
- 18
- Posts
- 570
Since I don't have your motherboard I cannot say for sure but make sure and check the Bios settings. I think I remember a setting on my board regarding wake from powered down.
Check the Device Manager and make sure the Ethernet port you are using is allowing it to wake the system.
There is also a setting in the Bios, for the RGB that allows them to be turned off during sleep.
07-01-2022 07:10 PM #3
- Join Date
- Feb 2022
- Reputation
- 10
- Posts
- 176
First make sure it is still shown as connected to the router on the router web GUI?
