Results 1 to 3 of 3
    New ROGer Array
    Feb 2021
    2
    Help identifying pinched cable - fan speed issue?
    Hello,
    Any help identifying this pinched cable would be greatly appreciated.
    I have had fan speed issues for a while now. The fans have a mind of their own and run full speed at times and not at others. The fan speed readout shows zero RPM in both the Armory Crate and BIOS. After reinstalling and updating the BIOS, Armory Crate, and everything else I could find, the fans continued ripping like a jet engine. I finally took the bottom cover off to take a look and noticed this pinched cable. I gave it a wiggle and resituated it under the case and after reassembly, the fans showed an RPM readout and they slowed down... for about a minute anyway.
    I don't know if this cable is the issue, but it seems like it very well could be. Does anybody know what this part is? I'd like to order a replacement.
    The cable has the white connector and runs under the edge of the fan and runs up towards the monitor. It's path is outlined in blue in one of the photos.
    Laptop is an ASUS GL704GW.
    Thanks in advance.
    ROG Guru: Orange Belt Array pndiode PC Specs
    pndiode PC Specs
    Laptop (Model)ASUS G752VL-DH71 Win 11 Pro 21H2
    MotherboardROG Maximus XII Formula
    ProcessorI7-10700K
    Memory (part number)G-Skill F4-3600C19Q-32GTZRB
    Graphics Card #1ROG Matrix GTX 980TI -P-6GD5 Bitspower Water Block
    Graphics Card #2ROG Matrix GTX 980TI -P-6GD5 Bitspower Water Block
    MonitorLG UltraGear 32GN50T-B
    Storage #1WD Black SN750 1TB
    Storage #2WD Blue 4TB (4 ea)
    CPU CoolerEK PE 360 (Top), PE 240 (Front), and Xres 100 Elite
    CaseROG Strix Helios
    Power SupplyThermalTake Toughpower 1200W
    Keyboard ROG Strix Scope RX
    Mouse Logitech MX Master S2
    Headset ROG Strix Fusion 300
    Mouse Pad Generic
    Headset/Speakers Bose Companion 3 Series II
    OS Windows 11 Pro 22H2
    Network RouterGeneric
    Accessory #1 Corsair ML140 (4 ea), Corsair ML120 (3 ea)
    Accessory #2 ASUS External 16X BLU-RAY Writer
    Jan 2016
    31
    297
    New ROGer Array
    Feb 2021
    2
    Quote Originally Posted by pndiode View Post
    Thanks! Â*I’ll give those threads a read to see if there’s anything I haven’t tried.Â*
Tags for this Thread
