I originally set my system up using the 5.2 radio as Backhaul from an AX92U. Originally is was showing as Excellent in the connections ratings but now it is showing Weak and I have already rebooted the AX92U.
This may have happened after the last firmware upgrade so I will not reboot the AXE11600 and will advise if that helps.
Edit: Rebooting the AXE16000 got me back to a GREAT connection with the 5.2.
As far as Ethernet, backhaul that should be it normal state if connections are correct.
Maximus Z790 Hero,
Intel i9-13900k
Intel BE200
