ASUS AX-11000 IPv6/Problem with SLAAC and MLD Proxy Option
Aztekaa
I am using IPv6 but I have a problem. I am using the Zyxel modem with bridge mode for DSL to ETH. When I selected the Native, all IPv6 tests failed. But when I entered the IP addresses from the System log page, all IPv6test are successful. My internet provider wanted me to select the DHCP Option to SLAAC and disable the MLD Proxy option but I did not find these options under the WAN or IPv6 tab.
Could you please help me with how to solve this problem?
jzchen
Level 14
Did you happen to check for the DHCP option in the LAN options/everywhere? Because as I understand it is a LAN side setting.
Yes I checked the all fields but did not find these options on everywhere.
