Results 1 to 7 of 7
    New ROGer Array
    Jul 2022
    4
    Unhappy amibios detected only 4-pin connector connected for the CPU issues
    I recently purchased a ROG STRIX X570-E GAMING WIFI II motherboard, I used my rig without any problems during 3 weeks
    but suddenly the amibios start to say "the system has only detected a single 4-pin connector connected for the cpu".
    I can boot but no internet, no sata access, access to my nvme main windows 11 partition only.
    I checked the cables, changed the cables but always the same message, I need my computer for working so I reinstall the
    ancient motherboard and have no problems.
    my config :
    x5900 amd cpu
    corsair vengeance LPX 32Gb x 4 sticks
    msi RTX 2070 super
    corsair HX1000 PSU (I also check with another PSU and same problem occurred)
    windows 11 pro 64bit
    the latest BIOS installed,
    I updated to the more recent AMD chipset drivers before the problem occurred
    I tried to reset CMOS, I change CMOS battery too, same problem...
    please help me
    ROG Guru: Brown Belt Array RedSector73 PC Specs
    Laptop (Model)FA506IU-AL130T x 2
    MotherboardROG CROSSHAIR VIII HERO (WI-FI)
    ProcessorAMD Ryzen 9 3900X 12-Core Processor
    Memory (part number)4 x G.SKILL F4-3800C14D-16GTZN 14-16-16-36 Samsung B-Die
    Graphics Card #1Gigabyte Aorus RTX 2080 Ti Xtreme WaterForce (GV-N208TAORUSX W-11GC)
    Sound CardArctis DAC
    MonitorAsus ROG Swift PG348Q
    Storage #1ADATA SX8200PNP 1TB
    Storage #22 x Samsung SSD 840 EVO 250GB
    CPU CoolerCoolermaster Liquid Pro Master 360
    CaseEVGA DG-87 Gunmetal Grey Gaming Case
    Power SupplyEVGA SuperNOVA G2 750W Gold Power
    Keyboard Corsair K95 RGB Platinum
    Mouse Corsair Gaming Sabre RGB Gaming Mouse
    Headset ARCTIS Pro Wireless
    Mouse Pad Cooler Master MP750 RGB Cloth Gaming Mouse Pad Extra Large
    OS Windows 11 64bit Pro
    Network RouterPfSence Intel i5-10210U 6 Port
    Accessory #1 TP-Link Gigabit 8&6 Port Switches
    Apr 2018
    66
    1,346
    Connect both E-ATX as recommended
    Set DOCP profile for your RAM
    Procedure for install of windows on a new NVMe drive.
    Enter BIOS, Advanced mode,
    1 - Make sure you unplug all SATA and USB drives, the M.2 drive has to be the only drive installed.
    2 - Go into the bios, under the boot tab there is an option for CSM, make sure it is disabled.
    3 - Click on secure boot option below and make sure it is set to other OS, Not windows UEFI.
    4 - Click on key management and clear secure boot keys.
    5 - Insert a USB memory stick with a UEFI bootable iso of Windows 10 on it.
    6 - Press F10 to save, exit and reboot.
    7 - Windows will now start installing to your NVME drive as it has its own NVME driver built in.
    8 - When the PC reboots hit F2 to go back into the BIOS, you will see under boot priority that windows boot manager now lists your NVME drive.
    9 - Click on secure boot again but now set it to Windows UEFI mode.
    10 - Click on key management and install default secure boot keys
    11 - Press F10 to save and exit and windows will finish the install.
    Hope you find this helpful.
    New ROGer Array
    Jul 2022
    4
    Quote Originally Posted by RedSector73 View Post
    thank you for your quick response and help, I will try this.
    do you know why this problem occurred ?
    Apr 2018
    66
    1,346
    At a guess, you may have corrupted the installation of windows. You have near to top-of-line CPU and bottleneck for power being supplied to the motherboard.
    ROG Guru: Green Belt Array ahfoo's Avatar
    Jan 2020
    160
    624
    It may be more than that, re set in your 8 pins connector and make sure the connector on both end of PSU and CPU are sit correctly and the rail not the issue.
    New ROGer Array
    Jul 2022
    4
    Unhappy
    hi,
    I tested with another PSU and I obtained the same error message,
    followed @RedSector73 procedures and reinstalled windows on a new nvme, stuck during installation because
    ethernet and wifi are out of service, I bypassed with OOBE\BYPASSNRO command
    finally reinstalled, installed asus drivers with CD-rom but nothing changed at all.
    No SATA, no wifi, no ethernet, cannot use some of the motherboard USB ports too.
    for me it's sound like a faulty material issues but I'm not a pro.
  7. #7
    New ROGer Array
    Jul 2022
    4
    Quote Originally Posted by ahfoo View Post
    Hi, thank you for the reply, I check the cables, tried with other cables and another PSU
    same problem. Windows fresh install on a new NVME disk changed nothing too.
    I also tried other memory sticks, nothing changed.
Tags for this Thread
