Results 1 to 8 of 8
    New ROGer Array BbyDckDddy PC Specs
    BbyDckDddy PC Specs
    Laptop (Model)MSI Prestige Evo 14
    MotherboardASUS ROG Crosshair VIII Hero
    ProcessorRyzen 9 5900x
    Memory (part number)TF4D432G3600HC18JDC01
    Graphics Card #1Radeon PowerColor Red Devil 6900XT
    MonitorPri: Viotek 2560x1440 Sec: Sceptre 1080x1920
    Storage #1Team Group 1TB M.2
    Storage #2Team Group 4TB M.2
    CPU CoolerASUS ROG Ryujin 360
    CaseCorsair 5000D Airflow
    Power SupplyASUS ROG Thor 1200W
    Keyboard Logitech G519
    Mouse Logitech G Pro Superlight
    Headset SteelSeries Artis Pro Wireless
    OS Windows 11
    Network RouterNetgear NightHawk
    Jul 2022
    4
    Inconsistent crashing/freezing unable to troubleshoot. Need advice.
    I am absolutely at a loss here.
    Short Version:
    Computer keeps freezing, but afterburner, performance monitor, and essentially any software used for troubleshooting freezes before the issue can be identified.
    Longer version:
    PC specs:
    Case: Corsair 5000D Airflow
    Fans: 10x Lian Li AL120 Uni
    MOBO: ROG x570 Crosshair VIII Hero
    OS: Windows 11
    CPU: Ryzen 9 5900x
    GPU: Radeon PowerColor RedDevil 6900XT
    RAM: 64 GB (4x16) T-Force 3600
    Cooler: Asus ROG Ryujin 360
    PSU: Asus ROG Thor 1200w
    TEMPS: In general, everything stays below 40*, GPU tops out at around 55* under stress tests.
    I don't think it matters, but I have 1Gigabit internet (ethernet), on a Nighthawk AC1900 router, and surfboard SB8200 Modem. House is ran with Cat8.
    Symptoms:
    *Crashes during regular use (Youtube, facebook, spotify) and gaming(no specific game, anything will cause it to freeze), nothing points towards anything being the sole cause.
    *I get something similar to screen tearing when it is about to freeze. It will just be white pixelated lines going across the screen, randomly flashing.
    *Task manager won't come up during freeze.
    *Letting it sit and waiting for upwards of 30-45 minutes doesn't relieve the issue.
    *Power switch will not turn off or reset PC during freeze.
    *Only way to reset during freeze is to flip PSU switch.
    *No temperature spikes on any components that I can tell. But again, it's frozen so I really can't check.
    *Airflow is optimal, thermals in general don't seem to be an issue and fans/AIO pump continue to run during freeze.
    *Only once has it completely crashed, lost power and went to a black screen with "No input detected". Every other time has been a freeze.
    *Prior to the issues at hand, I noticed one stick of RAM had been kind of off color, no longer the case.
    Attempts at fixing and/or diagnosing in no particular order(But everything was attempted again post clean windows installs):
    Clean install windows 10
    Clean install windows 11
    Ran DDU and did clean install of new Graphics drivers(Also tried rolling back drivers prior to this).
    Removed one channel of RAM at a time trying to eliminate one set/stick. Shuffled them around and attempted again. Was unable to diagnose.
    Put GPU and CPU under various stress tests via programs such as 3D mark.
    Ran MemTest64 for 30ish minutes - no errors.
    BIOS and Task manager both recognize every component, and running at appropriate frequencies, voltages, etc.
    Completely took apart PC, thoroughly cleaned and replaced all thermal compound/pads.
    Replaced MOBO. Old MOBO is ASUS Prime X570 Pro, new is ASUS ROG Crosshair VIII - Issue persists.
    New sticks of RAM on the way, should be here tomorrow - Direct replacements.
    I am at my wits end with this thing. Admittedly, I am not a professional when it comes to diagnosing computers. I feel pretty comfortable digging around in BIOS and what not. But I simply cannot figure out the issue I'm having. I am open to all suggestions here. I've been trying to figure this out for a few days now, and have already thrown a motherboard at it. Now I have new RAM coming. Before I throw any other parts at it, does anyone have any suggestions? Any software I can run to help diagnose if any particular component is an issue? If you need more info, please let me know and I will get it to you.
    Administrator Array Silent Scone@ROG's Avatar
    Mar 2016
    233
    2,711
    Hello,
    The white pixelated lines and screen artefacts point towards a GPU issue.
    First and foremost you need to make sure there is no overclock whatsoever.
    This means Optimised Defaults. No XMP enabled, and no PBO.
    Are you using a GPU riser cable?
    Are you able to use an alternative GPU to test?
    BbyDckDddy PC Specs
    OS Windows 11
    Jul 2022
    4
    Quote Originally Posted by Silent Scone@ROG View Post
    Hello,
    I replied to this yesterday. I'm not sure why it didn't save. Regardless, No overclocks, no riser cables, I'm really just trying to eliminate anything else before dumping money into a new GPU. I haven't been able to swap my wife's in yet. She uses hers for work quite frequently, but will at the first chance I get. I believe my warranty -JUST- (conveniently) lapsed. Any other ideas? Thanks for the reply.
    Moderator Array
    Apr 2019
    66
    1,716
    Hi BbyDckDddy,
    Does the issue also occur on ROG CROSSHAIR VIII HERO BIOS 4201 and PRIME X570-PRO BIOS 4403 with bios all default settings(no OC)?
    Do you have the issue since first build or after any settings or components changed?
    Have you tried new sticks of RAM and another SSD to install windows?
    ROG Guru: Brown Belt Array RedSector73 PC Specs
    Laptop (Model)FA506IU-AL130T x 2
    MotherboardROG CROSSHAIR VIII HERO (WI-FI)
    ProcessorAMD Ryzen 9 3900X 12-Core Processor
    Memory (part number)4 x G.SKILL F4-3800C14D-16GTZN 14-16-16-36 Samsung B-Die
    Graphics Card #1Gigabyte Aorus RTX 2080 Ti Xtreme WaterForce (GV-N208TAORUSX W-11GC)
    Sound CardArctis DAC
    MonitorAsus ROG Swift PG348Q
    Storage #1ADATA SX8200PNP 1TB
    Storage #22 x Samsung SSD 840 EVO 250GB
    CPU CoolerCoolermaster Liquid Pro Master 360
    CaseEVGA DG-87 Gunmetal Grey Gaming Case
    Power SupplyEVGA SuperNOVA G2 750W Gold Power
    Keyboard Corsair K95 RGB Platinum
    Mouse Corsair Gaming Sabre RGB Gaming Mouse
    Headset ARCTIS Pro Wireless
    Mouse Pad Cooler Master MP750 RGB Cloth Gaming Mouse Pad Extra Large
    OS Windows 11 64bit Pro
    Network RouterPfSence Intel i5-10210U 6 Port
    Accessory #1 TP-Link Gigabit 8&6 Port Switches
    Apr 2018
    66
    1,346
    T-Group Ram, you mention, its config 4x16 (is that two kits of 2x16) with 'TF4D432G3600HC18JDC01' as that is 2x16 kit.
    From what I read of your posts, you have a memory issue going on. Try using one 2x16 kit (DOCP 3600) (on its own from CPU ram slots 2 & 4) and see if the issue goes. Just be aware, your install of windows was most likely corrupted if you had memory issue when install is done.
    For x4 DDR4 kit, you really need to be sure it is approved for use, you can get 2 X nearly anything to work these days (even this had issues back in the day), but not 4 X Anything https://www.amd.com/en/products/ryzen-compatible-memory
    I doubt these kits were ever approved or made to be used 4xRAM. Be interesting to know who is the manufacturer of the actual ram chips, Hynix or Micron (at a guess) CL 18 @ 3600
    BbyDckDddy PC Specs
    OS Windows 11
    Jul 2022
    4
    Quote Originally Posted by STARRAIN@ROG View Post
    Hi BbyDckDddy,
    Hi, thanks for replying.
    Yes, issues with both MOBOs and bios with no OCs.
    Only had issues fairly recently, about the last two weeks at this point, I believe. Have had this variation of the build for at least six months, but I believe right around eight months.
    No to both the RAM and SSD. Ram is on the way though. I am really hoping the ram fixes it.
    Thanks again!
  7. #7
    BbyDckDddy PC Specs
    OS Windows 11
    Jul 2022
    4
    Quote Originally Posted by RedSector73 View Post
    Interesting. I could've swore I checked compatibility when I bought everything, but now it doesn't appear so. However, yes, it is two kits. If that is the issue, I wonder why it ran solid for about eight months. Think it just gave finally?
  8. #8
    Apr 2018
    66
    1,346
    Quote Originally Posted by BbyDckDddy View Post
    Eight months of 'ok' is really a good result, but I'm wondering if you maybe were not using DOCP profile and was loose & slow enough at default to just not be present.
    The system, if set DOCP will use DOCP profile (read from slots 2 & 4 then assumed 1 & 4 you could try swapping the matched kits and see if this helps) for the base timings and voltage, but sub timings can change. A Bios update or reset and since that you have been unlucky, and just keeps trying an unstable setting, rather than one you got lucky with, maybe ?
    From my experience, video card gone bad is artefacts then death, death of video output, or non-stop driver stop responding to the system errors and restarted. I've had one that would freeze the system, but that was like 15 years ago.
    T-Group Ram is good, used it myself, just never used 4x16 in Ryzen system from them. To be honest, on first read, I was surprised it worked at all.
Tags for this Thread
