Results 1 to 10 of 14
08-02-2022 02:12 AM #1
- Join Date
- Jul 2022
- Reputation
- 10
- Posts
- 4
Armoury Crate / slow perfmormance
Hey, I have the M16 2022 With the i7 and 3050. I have a small problem out of no where and hope that somone can help me. So when I want to switch my keyboard lightning option to Static, it takes a time to load on my keyboard. The other options are fast to load but just loading or changing color of Static became slow. Also while rebooting my system this option takes time. I didnt have the problem from the start it just came out of no where and its really anoying because I always use this option. I have the latest Armoury Crate Version. So is there maybe anyone who could help me please?
08-02-2022 03:11 AM #2
MrAgapiGC PC Specs Motherboard Asus Maximus XI Code Processor 9900K Memory (part number) CMK32GX4M4B3600C18 Graphics Card #1 STRIX-GTX1080ti-O8G-GAMING Monitor AOC AGON AG2701QX (2) Storage #1 Samsung 960 EVO 256GB Storage #2 Kingston Savage 500GB CPU Cooler Nzxt X74 360mm AIO Case Nzxt H700 Power Supply EVGA 850 G2 Keyboard Logitech G810 Mouse Asus Spartha Headset Hyper X Cloud Revolver S Mouse Pad Hyper X Fury S 900mx420mm Headset/Speakers Logitech Z337 OS Windows 10 64btis Network Router TpLink Archer C9 Accessory #1 EKWB FANs all of them
- Join Date
- Nov 2011
- Reputation
- 87
- Posts
- 1,889
08-02-2022 04:15 AM #3
- Join Date
- Jul 2022
- Reputation
- 10
- Posts
- 4
08-02-2022 04:23 AM #4
- Join Date
- Nov 2011
- Reputation
- 87
- Posts
- 1,889
old version will not be possible. is not a thing that you can downgrade. I did send a text let me see what can be done i do not promise anything. but i thing that was done for a reason. I am tracking also some other issues as well. but 99.9% will not see it
I thing the code was improve to make the app faster and more responsive. let see what it can be done. Normally i do not post on forums. but i take some notes to try do duplicate stuffLearn, Play Enjoy!
08-02-2022 06:18 AM #5
Murph_9000 PC Specs Motherboard ROG Crosshair VIII Extreme Processor AMD Ryzen 5950X Memory (part number) Crucial Ballistix DDR4-3600 CL16 (BL16G36C16U4B.M16FE1) Graphics Card #1 ROG Strix Radeon™ RX 6750 XT OC Edition 12GB GDDR6 Monitor ROG Strix XG43UQ, XG27AQM Storage #1 Seagate FireCuda 530 CPU Cooler ROG Ryujin II 360 Case ROG Strix Helios Power Supply ROG Thor 1200W Platinum Keyboard ROG Strix Scope RX, ROG Claymore II Mouse ROG Keris Wireless, ROG Chakram X Headset ROG Delta S Mouse Pad ROG Scabbard II OS Windows 11 Pro Network Router ROG Rapture GT-AX6000 Accessory #1 ROG Eye S Accessory #2 ROG Strix Magnus Accessory #3 LINKUP Ultra PCIe 4.0 x16 Riser Cable - Right Angle - 20cm
- Join Date
- May 2022
- Reputation
- 70
- Posts
- 255
I suspect there's something else going on here, but it's possible that you could be getting poor performance due to the fairly bad memory leak in LightingService.exe (particularly if you have "Aura Performance Mode" enabled for smoother lighting animation). It's leaking over 1GB RAM per day for me, although the latest version has solved a slowdown I was personally encountering that seemed to go along with the leak. On systems with less memory, that leak is likely to result in poor performance after it has been running for a while, due to its pages getting pushed out to swap. After a restart of the service, it starts out around 12MB for me, grows to about 20MB fairly quickly, then steadily grows seemingly without limit. There's really no legitimate reason for it to be growing into the 100s of MB or past 1GB over time.
This is not something to do with services in general, but it seems safe enough for LightingService. Don't go around restarting other services unnecessarily or carelessly, and don't change the startup options without knowing what each service actually does (the descriptions don't tell the full story in some cases). To restart LightingService and temporarily clear the excessive memory usage, do the following:
1. Win+R, services.msc
2. Scroll down to LightingService
3. Right click on LightingService
4. Click "Restart" on the context menu
This will kinda break Aura briefly, but it should recover automatically and put the lights back to their last configured mode within a minute or so.
As I said, I don't recommend restarting services randomly or carelessly, but it seems to work ok for LightingService. It can clear the high memory usage for a while, and possibly other transient issues. It's less hassle than rebooting. Other services may not restart so safely or cleanly, and can break things if poked in the wrong way.
Your problem may well be unrelated, this is just something to look for and try to see if it gives any improvement.
08-02-2022 02:35 PM #6
- Join Date
- Nov 2011
- Reputation
- 87
- Posts
- 1,889
Ehh no.
the high use of lighting services are cause by the ram sync with aura. if you unsync it that drops to almost 0. There is nothing it can be done. will happens with all ram all brands that use aura sync. (armory crate) lighting services has 2 purposes. 1 sync and 2. program the motherboard. lighservices is part of the file that creates the exel file to program the rom ,the aura chip on the boards. automatic will add the current configuration once you enter armory crate aura.Learn, Play Enjoy!
08-02-2022 02:42 PM #7
- Join Date
- Nov 2011
- Reputation
- 87
- Posts
- 1,889
08-02-2022 02:49 PM #8
- Join Date
- Jul 2022
- Reputation
- 10
- Posts
- 4
08-02-2022 02:54 PM #9
- Join Date
- May 2022
- Reputation
- 70
- Posts
- 255
08-02-2022 03:04 PM #10
- Join Date
- Nov 2011
- Reputation
- 87
- Posts
- 1,889
That i can not duplicate. on all test scenarios, once i unsync my ram lightservices still very very low. Here is my current computer task manager.
I use a z590-e and my computer is using what appears on asus z590-e website drivers, or what windows give. The images are without ram sync. i have test also these a lot. and without ram light services still the same
Since i can not duplicate, please report the issue and follow the post google forms to send the logs.
Learn, Play Enjoy!
