Results 1 to 4 of 4
    New ROGer Array
    Sep 2020
    4
    Help with ROG STRIX B450-F GAMING
    Hello! I wanted to know if anyone knows this
    I had a ROG STRIX B450-F GAMING motherboard with a 5 reyzer 2400 processor and it worked very well with a ROG-STRIX-RX590-8G-GAMING but now that I switched to a Reyzer 9 5900x processor in games the fps dropped to 5 or 10 and that did not happen with the Reyzer 5 2400
    I must clarify that the PC works very well in general, it is very fast and all my problem is that the games cannot be played!
    I have 56MB Ram
    I have bios version 4801
    I hope you can help me
    New ROGer Array Murph_9000 PC Specs
    Murph_9000 PC Specs
    MotherboardROG Crosshair VIII Extreme
    ProcessorAMD Ryzen 5950X
    Memory (part number)Crucial Ballistix DDR4-3600 CL16 (BL16G36C16U4B.M16FE1)
    Graphics Card #1ROG Strix Radeon™ RX 6750 XT OC Edition 12GB GDDR6
    MonitorROG Strix XG43UQ, XG27AQM
    Storage #1Seagate FireCuda 530
    CPU CoolerROG Ryujin II 360
    CaseROG Strix Helios
    Power SupplyROG Thor 1200W Platinum
    Keyboard ROG Strix Scope RX, ROG Claymore II
    Mouse ROG Keris Wireless, ROG Chakram X
    Headset ROG Delta S
    Mouse Pad ROG Scabbard II
    OS Windows 11 Pro
    Network RouterROG Rapture GT-AX6000
    Accessory #1 LINKUP Ultra PCIe 4.0 x16 Riser Cable - Right Angle - 20cm
    May 2022
    59
    112
    BIOS 4901 is available for your board, and probably worth a try (the AGESA 1.2.0.7 update solves significant performance issues on Windows 11):
    https://rog.asus.com/motherboards/ro...helpdesk_bios/
    AMD Adrenalin 22.7.1 is also worth a try. It gives a massive boost to OpenGL performance on RX 6000. I don't know if you'd see the same benefit on RX 500 but it was a vast improvement for newer cards.
    https://www.amd.com/en/support/kb/re...rad-win-22-7-1
    Also, latest 4.06 AMD chipset drivers may help (the Adrenalin installer may include these on a full install, I can't remember):
    https://www.amd.com/en/support/chips...ocket-am4/b450
    New ROGer Array
    Sep 2020
    4
    Quote Originally Posted by Murph_9000 View Post
    Thank you very much for helping me Murph_9000
    I am going to update to the new bios and I will be doing the tests that you tell me and I will tell you how it went
    Thank you
    New ROGer Array
    Sep 2020
    4
    Hello Updating
    Hello how are you!!
    Updating I put in a new bios and it improved much more, but when entering the games it works fine sometimes and sometimes out of nowhere the fps drops from 0 to 5, I don't know what it is since the PC in general works wonderfully, now sometimes it works well and sometimes it works badly.
    I don't know what to do! it will not be the processor or my GPU
    It definitely works very poorly! I will have to put the ryzen 5 back
Tags for this Thread
