Strix G15 6800h and 3070ti questions - resizable bar and pci-e x8
CRJ84
Hello All 🙂
Just bought the Asus Rog Strix G15 6800h 3070ti laptop.
I have some questions, which I was not able to google any answers.
1) Resizable bar only enables when I turn off the integrated graphics, so when enabling the MUX switch, is that correct?
2) The 3070ti only runs max pci-e x8 4.0, I thought that the 6800h was able to run x16, is this a bug or is it only able to run x8?
Loving the laptop in silent mode when gaming WoW and locked to 100 fps, almost completely silent.
Thank you 🙂
4 REPLIES 4
CRJ84
Alright found out that PCI-e 4 x8 is just as fast as PCI-e 3 x16, so there should be no bottleneck there for the 3070ti.
So just answered my 2nd questions, almost 😄
smlgunes
I still cant believe i finally find a person have an issue which are i already have. I have a 6900hx and 3070 ti rog strix i cant find a way to enable resizable bar to enable it its just not showing on nvidia control panel on anytime mux switch active or not.(my laptop has a mux switch too) it cant be enabled, nvidia and asus responded me and they said nothing wrong with my laptop.
Also i cant figure out why my pci-e working on x8 (according to gpu-z). I am checking asus website everyday for an bios update maybe it will solve my problems but i dont have a solution for our problem. But you know its happening on my laptop too.
CRJ84
It seems that Resizable bar is only enabled if you disable the integrated Graphis, so enabling the MUX switch.
If you do this you should be able to go to Nvidia Control Panal -> Help -> System Information -> In the list to the right it says Resizeable Bar - Yes.
For ryzen the maximum PCI-e is x8, but it is gen 4 so it is more then enough bandwith for the 3070ti, so there is actually no problems here.
But its not working for me when i enable mux switch from armoury crate nothing change in nvidia control panel reBar option missing completely
