Hi guys, I'm having an annoying issue with my Z690 formula disconnects usb under load while gaming. Keyboard mouse, steering wheels suddenly stops working and the only solution to get them to work again is to restart the PC and manually disconnect and reconnect all usb peripherals.
I didn't have this issue with my former motherboard Z270 Formula, all with same setup except for Mobo,CPU and RAM
I have also just try running with default bios setup. but with same results.
Motherboard: ROG MAXIMUS
Bios: 1601
Processor: Intel Core i7-12700K Processor
Memory: Corsair PLATINUM RGB 32GB (2x16GB) DDR5 DRAM 6400MHz
Are there any other that have or had same issue?
Thanks in advance.
