HoenNWacco wrote:
Hi everyone. I got x99 system just a few weeks ago. I am using Crucial Ballistix BL8G32C16U4B x 4 pieces in total 32GB ram in my system. My problem is I can't go over 2600MHZ with this rams with XMP or MANUAL none of them makes difference. With single, dual or quad slot I tried both of them nothing worked. Can anyone help me about my situation? Thanks.
Motherboard: Asus Rampage V Extreme X99
Bios Version: 4101
Processor: Intel i7 5960X
Ram: 4x Crucial Ballistix BL8G32C16U4B
Hi, on this motherboard which is quad channel memory configuration, you should only use quad channel memory kits.
Have a look here:
https://rog.asus.com/forum/showthread.php?57038-Don%92t-combine-memory-kits!-The-meat-and-potatoes-o...
MB: Asus Rampage V Extreme (WC loop1 rad 120x3) Bios 4101
CPU: Core i7-6950X (WC loop2 rad 120x9)
MEM: G.Skill Flare X 32GB (4x8GB) DDR4 3200MHz@CAS14/CR1
GPU: ZOTAC Trinity RTX 3090 Watercooled [double side] {PCIE_X16/X8_3 slot} (WC loop3 rad 120x9 + 140x9)
SSD: Corsair MP600 PRO XT 2To SSD M.2 NVMe w/ heatsink
HDD: 4 x 10TB Seagate IronWolf RAID 0 (WC loop1)
PSU: EVGA NEX 1500 1650W + Seasonic Fanless TX-700W
Main Screen: ASUS ROG Swift PG43UQ 4K 144Hz G-Sync/FreeSync HDR
