Strix X299 Monoblock?
Stormwind81
So I want to buy a new watercooling block for my old ROG Strix X299 E-Gaming. (not confusing with the new E-Gaming II).
EKWB has an monoblock:
https://www.ekwb.com/shop/ek-quantum-momentum-rog-rampage-vi-encore-d-rgb-plexi?___store=default
But it is for the rampage VI.
I have no idea if it maybe also fits for my motherboard.
Does anyone know?
Or can anyone recommend a monoblock for my motherboard here?
Thanks
Nate152
Hi Stormwind81
The EK monoblock is for the Rampage VI Encore, the X299-e gaming is not on the compatibility list.
The one you're looking for from EK is end of life, so you may have to look on ebay to find one.
I found one from bitspower for the X299-E Gaming.
https://www.caseking.de/Bitspower-Monoblock-fuer-ASUS-ROG-STRIX-X299-E-GAMING-RGB-Nickel-Acryl-WAHE-...
Nate152 wrote:
Hi Stormwind81
Thank you very much.
That's also what my research lead me to yesterday.
Question is, if paying ~180€ is worth for having a new cpu cooler block.
Mine right now, from EKWB, clogs very frequently, so I have to clean it every 3 to 5 months.
My idea was to buy a monoblock to have:
- slightly better cooling performance
- better loop flow or less clogging going on
- cooling of Motherboard VRAMs
