Completed my first build in 10 years with temps question
blade7658
As per the title, it has been quite a while since my last build. I am very happy with my new build with the build in my profile (in short, i7-12700k with H150i and Strix 3080). The only thing to add is I have 12 fans in my case (6 for push-pull exhaust on my AIO and 6 intakes in the slots on the front and right of the 5000X case).
I have done a lot of searching around and think I know the answers to a few questions, but figured I would ask.
My question is about temperatures (environment is usually 22c).
My CPU is usually around 29 at idle but gets to 89 under Cinebench load. I think idle is icy cold but a bit worried about the load. It sometimes gets voltage throttled (I turned on AI overclock and have XMP I for my memory) but never temperature throttled. I am guessing my load temp is fine but just making sure.
My GPU idles 36-38 but I keep the case and GPU fans at approx 50% to keep it there. It isn't noisy, but certainly not silent. Under load (Heaven at Ultra/Extreme) it climbs to 58. I feel like the idle is a bit warm (or at least, shouldn't take 50% fans to be high 30s) but I think the load temp is fine, but again just making sure after all the conflicting data I have seen out there.
Are these temps OK? Is idle "too" good and I can turn down my fans when I am working on email, etc?
Greatly appreciate any insights this fine community might have.
ahfoo
Maybe can share the following
1. core temp.
2. CPU package temp.
5. Ambient temp.
blade7658
The CPU temps above are package temps. The core temps are over quite a spread with some being lower than package and some being around package temps.
The environmental temp is around 22.
