Project: Raptor Lake
samarlian
Massive thanks to Intel for asking me to do a build for them.
Thought i would share by build log for the project
System Specs
1 x Intel cpu under NDA
1 x ASUS ROG STRIX Z690 -E GAMING WIFI
1 X ASUS TUF GAMING RTX3090 OC 24GB
2 x Corsair Dominator Platinum RGB DDR5 5200MHz 32DGB
1 X Corsair HX1200w PSU
1 x Samsung 980 PRO 2TB M.2 NVMe
1 X EK Quantum Velocity CPU Block and backplate
1 x EK Quantum Vector RTX3090 Block
1 x EK Quantum Kinetic 360 D5-Distro
2 x EK Quantum Surface S360 radiator
10 x EK Quantum Torque fittings
16 x EK Quantum Torque 90 degree fittings
4 x EK Quantum Torque 45 degree fittings
8 x EK Quantum Torque rotary offset
6 x EK Varder X3M D-RGB fans
2 x EK Cryofuel Navy Blue
1 x Antec Cannon case
95023
95024
95025
95026
95027
12 REPLIES 12
samarlian
Panels preped and painted
95030
95031 95032
95033
Custom vinyl applied
samarlian
ASUS TUFRTX3090 stripped cleaned off excess TP and fitted EK Gpu block
samarlian
case coming together , panels left to weather and add grime to look distressed same as vinyl.
samarlian
Been pushing it hard last 2 days, just tubing left to do, leak test make a panel to cover cables under the distro and add final touches.
samarlian
Bends done and leak tested and panels weathered
samarlian
Leak test done pull it apart and add NDA cpu and add final touches
Silent_Scone
Super Moderator
Looking good. My only real concern with these types of builds dust. Just that extra level of maintenance that's always best left to test beds
yeap I agree but this is a show piece build for Intel
