Z690 Maximus Extreme Q-LEDs covered by plastic shroud, how to read them
jbmerrill1954
Hello, as the title says, I can't see how to read the Q-LEDs on the motherboard as they are covered by a plastic shroud it seems. Can that shroud be removed? My computer is completely dead and I can only see the Q-Code LED giving me codes 01, 20, 50, and 53.
Any help would be greatly valued.
Thanks,
B.
ahfoo
It should not have covered it as it just has a cut out above the start key and flex key. Can you post image here?
Here is a picture of the motherboard, the q-leds are covered by the plastic shroud that houses the q-code led
