Results 1 to 10 of 36
09-21-2022 11:13 PM #1
Hopper64 PC Specs Motherboard Asus MZ790E Bios 0816 Processor i9 13900KS Memory (part number) F5-7800J3646H16GX2-TZ5RK Graphics Card #1 Asus 4090 Strix Sound Card Creative SB X4 Monitor Asus ROG XG349C Storage #1 Samsung 990 Pro CPU Cooler Quantum Kinetic TBE 300 D5 with XTOP DDC 4.2 Case Phanteks Enthoo Elite Power Supply Corsair AX1600i Keyboard Asus ROG Claymore 2 Mouse Asus ROG Gladius III OS Windows 11 64
- Join Date
- Nov 2012
- Reputation
- 70
- Posts
- 2,612
Armoury Crate V5.3.20 won't update Gladius [Resolved]
Can't get the update to work on this version. I click update and it does not work.
Item Version
Armoury Crate UWP App 5.3.2.0
ROG Live Service 1.6.3.0
Aura Service (Lighting Service) 3.05.76
Armoury Crate lite service 5.3.1
Aura Wallpaper Service 1.3.4.0
ASUS AIOFan HAL 1.1.49.0
ASUS AURA Extension Card HAL 1.1.0.18
ASUS AURA Motherboard HAL 1.3.7.0
ASUS Aac_GmAcc HAL 1.0.9.0
ASUS Keyboard HAL 1.2.10.0
ASUS MousePad HAL 1.0.3.5
AacAudioHal 1.3.46.0
AacDisplay 1.2.27
AacVGA 0.0.4.3
KingstonDram 1.1.12
AURA DRAM Component 1.1.23
ENE RGB HAL 1.1.40.3
ENE_EHD_M2_HAL 1.0.9.12
PHISON HAL 1.0.9.0
Patriot Viper DRAM RGB 1.0.9.4
Patriot Viper M2 SSD RGB 1.1.0.2
Universal Holtek RGB DRAM 1.0.0.3
WD_BLACK AN1500 1.0.14.0
You can see the Gladius 3 in the device menu, but it is not on the Aura Menu because the device needs the update:
I meant version 5.3.2.0 but it won't let me edit the title.Last edited by Hopper64; 09-21-2022 at 11:15 PM.
09-22-2022 01:14 PM #2
Nate152 PC Specs Motherboard ROG Strix Z690-F Gaming WiFi Processor i7-12700KF Memory (part number) Kingston Fury Beast 16GB (2x8GB) 6000MT/s (KF560C40BBK2-16) Graphics Card #1 ROG Strix 3090 Ti LC OC Sound Card ROG SupremeFX Monitor HP ZR30w Storage #1 Seagate Firecuda 530 1TB CPU Cooler EK Quantum Velocity2 Case Thermaltake Tower 900 Power Supply EVGA Supernova 1600 T2 Keyboard ROG Falchion NX / Strix Flare II/Azoth Mouse ROG Chakram X/Chakram Core/Spatha X/Harpe Ace Headset ROG Delta S Animate Mouse Pad Steelseries Prism XL / ROG Scabbard II/Hone Ace OS Windows 11 Home Accessory #1 2x Swiftech Maelstrom X300 D5 V2 Accessory #2 2x Hardware Labs SR2 560 MP radiators Accessory #3 Lamptron FC-5 V3 fan controller
- Join Date
- Feb 2013
- Reputation
- 408
- Posts
- 17,903
Hi Hopper64,
Make sure you have the wireless dongle connected to a usb port and the cable connected to your ROG Gladius III and a usb port.
You might need to set the wireless switch on the ROG Gladius III to OFF or 2.4GHz wireless mode.
Then try the update.
09-22-2022 01:40 PM #3
- Join Date
- Nov 2012
- Reputation
- 70
- Posts
- 2,612
I will try that when I get off work and let you know. Thanks!!
09-22-2022 01:49 PM #4
- Join Date
- Feb 2013
- Reputation
- 408
- Posts
- 17,903
09-22-2022 08:19 PM #5
- Join Date
- Nov 2012
- Reputation
- 70
- Posts
- 2,612
I tried that but no change. I have updated previously and prompted to add the dongle with a FW update but not with just software only. I still tried it but it still refuses to update. No change in outcome. Thanks.
09-22-2022 09:31 PM #6
- Join Date
- Nov 2012
- Reputation
- 70
- Posts
- 2,612
Tried my older Gladius II origin. Same result. Won’t update.
09-22-2022 09:36 PM #7
- Join Date
- Feb 2013
- Reputation
- 408
- Posts
- 17,903
Have you tried the wireless switch to 2.4GHz wireless and OFF?
Does it give you any message about the update?
09-22-2022 09:53 PM #8
- Join Date
- Nov 2012
- Reputation
- 70
- Posts
- 2,612
I tried the wireless switch and no change. I don't see an OFF button on this mouse. There's a switch for bluetooth, wireless, and a setting in the middle for the wired connection, but no off button. Nothing in the manual as well on an off button.
09-22-2022 10:08 PM #9
- Join Date
- Feb 2013
- Reputation
- 408
- Posts
- 17,903
Yes my mistake, it would be wired.
So, you've tried with the switch to both wired and 2.4GHz wireless mode and neither get you to update.
Normally, you'd set the switch to 2.4GHz wireless mode, connect the cable to your mouse and pc and do the update in Armoury crate.
If it's not updating, I wonder if a simple restart of your pc might get it to update.
Try using motherboard usb ports for the dongle and cable. If you're using a usb-c port, try another usb port.Last edited by Nate152; 09-22-2022 at 10:12 PM.
09-22-2022 10:19 PM #10
- Join Date
- Nov 2012
- Reputation
- 70
- Posts
- 2,612
Tried a different USB port. No change. Tried Wi-Fi setting and wired setting with dongle in different ports. No change. I had an older gladius II origin. It won’t update that either. Same behavior.
