Results 1 to 9 of 9
    ROG Member Array JamesJB50 PC Specs
    JamesJB50 PC Specs
    MotherboardAsus ROG MAXIMUS XII EXTREME EATX LGA1200
    ProcessorIntel Core i7-10700K 3.8 GHz 8-Core Processor
    Memory (part number)Corsair Vengeance RGB Pro 64 GB (4 x 16 GB) DDR4-3200 CL16
    Graphics Card #1MSI GeForce RTX 2080 SUPER 8 GB GAMING X TRIO
    MonitorAsus TUF Gaming VG27AQ 27.0" 2560x1440 165 Hz
    Storage #1Samsung 970 Evo Plus 500 GB M.2-2280 NVME
    Storage #2Samsung 970 Evo Plus 2 TB M.2-2280 NVME
    CPU CoolerNZXT Kraken Z63 98.17 CFM Liquid CPU Cooler
    CaseCorsair Crystal 680X RGB ATX Mid Tower
    Power SupplyEVGA SuperNOVA 850 850 W 80+ Titanium Certified Fully Modular ATX Power Supply
    Keyboard Logitech G910 Orion Spark RGB Wired Gaming Keyboard
    Mouse Logitech G900 CHAOS SPECTRUM Wireless Optical Mouse
    Headset Logitech G933 Artemis Spectrum 7.1 Channel Headset
    Headset/Speakers Logitech Z906 5.1 Surround Sound Speaker System - THX, Dolby Digital and DTS Digital Certified
    OS Windows 11 Pro
    Network RouterUbiquiti Dream Machine Pro
    Accessory #1 HTC Vive Cosmos Elite Virtual Reality System
    Accessory #2 Thrustmaster T.16000M FCS Flight Pack Includes Joystick Throttle and Rudder Pedals (PC)
    Accessory #3 Logitech G920 Driving Force Racing Wheel + Logitech G Driving Force Shifter Bundle
    Oct 2020
    15
    ROG MAXIMUS XII EXTREME Bios rgb and lighting Settings, Please Help..
    Hi guys was wondering if I could get some help.
    I have the latest BIOS and since I had that installed I can't seem have all the lighting turn off completely when the system shuts down.
    I was able to do this in the previous BIOS versions but I can't seem to find the settings now.
    Here is a pic what I am talking about;
    https://ibb.co/0Gqfcg9
    As you can see the lights like the RGB inside etc are on. Also My mouse is still powered when its like this.
    So where in the BIOS settings must I go to to have all those turn off when the system shuts down?
    I don't want to keep turning the switch off on the PSU constantly ,I'm afraid its gonna wear out
    Thank you in advance for the help.
    ROG Guru: White Belt Array
    Dec 2014
    6
    93
    There's should be settings in your BIOS like these. Try to disable.
    JamesJB50 PC Specs
    OS Windows 11 Pro
    Oct 2020
    15
    Quote Originally Posted by Rocket Scientist View Post
    I tried those I think and All doesn't turn off when system is shut down
    Dec 2014
    6
    93
    Quote Originally Posted by JamesJB50 View Post
    There is should be stealth mode for Aura in soft off states. Try to set it in stealth mode in your BIOS.
    Also make sure Aura is disabled in Armoury Crate software (if it installed) or temporarily remove this software to avoid settings override conflict.
    Moderator Array
    Apr 2019
    75
    1,954
    Hi JamesJB50,
    If you would like to disable standby power of the USB connected device, please refer to the following link.
    https://www.asus.com/support/FAQ/1042220/
    For the lighting effect, please refer to the instruction in the following link.
    https://www.asus.com/support/FAQ/1045607/#ggg
    JamesJB50 PC Specs
    OS Windows 11 Pro
    Oct 2020
    15
    Would that be under Aura Sync in the Armory Crate?
    Edit;
    Nvm I think I found it.
  7. #7
    JamesJB50 PC Specs
    OS Windows 11 Pro
    Oct 2020
    15
    Quote Originally Posted by STARRAIN@ROG View Post
    Hi JamesJB50,
    I did what ya guys said but as you can see in the first pic some of the lights are still on,the others are finally off when the system shuts down;
    https://ibb.co/SsTCPHQ
    The second Pic is the settings;
    https://ibb.co/Tcw37cB
    I did uninstall Armory Crate but with no luck so I reinstalled it.
  8. #8
    ROG Guru: Orange Belt Array pndiode PC Specs
    pndiode PC Specs
    Laptop (Model)ASUS G752VL-DH71 Win 11 Pro 21H2
    MotherboardROG Maximus XII Formula
    ProcessorI7-10700K
    Memory (part number)G-Skill F4-3600C19Q-32GTZRB
    Graphics Card #1ROG Matrix GTX 980TI -P-6GD5 Bitspower Water Block
    Graphics Card #2ROG Matrix GTX 980TI -P-6GD5 Bitspower Water Block
    MonitorLG UltraGear 32GN50T-B
    Storage #1WD Black SN750 1TB
    Storage #2WD Blue 4TB (4 ea)
    CPU CoolerEK PE 360 (Top), PE 240 (Front), and Xres 100 Elite
    CaseROG Strix Helios
    Power SupplyThermalTake Toughpower 1200W
    Keyboard ROG Strix Scope RX
    Mouse Logitech MX Master S2
    Headset ROG Strix Fusion 300
    Mouse Pad Generic
    Headset/Speakers Bose Companion 3 Series II
    OS Windows 11 Pro 22H2
    Network RouterGeneric
    Accessory #1 Corsair ML140 (4 ea), Corsair ML120 (3 ea)
    Accessory #2 ASUS External 16X BLU-RAY Writer
    Jan 2016
    31
    297
    BIOS:
    Advance\APM Configuration\ErP Ready\Enable(S4+S5).
    Note: When the computer is shutdown all USB ports will not work (charging). External devices using USB ports will no longer be powered on. BIOS flashback and Clear CMOS buttons will not function, and all your lights will be off. Somewhat like using the power supply on/off switch.
    Bios Erp S4 or S5?
    https://rog.asus.com/forum/showthrea...s-Erp-S4-or-S5
  9. #9
    JamesJB50 PC Specs
    OS Windows 11 Pro
    Oct 2020
    15
    Quote Originally Posted by pndiode View Post
    BIOS:
    Awesome thank you that worked
    All lights are off when the system is shutdown I don't have to keep flipping the switch on the PSU anymore.
