Rampage VI Extreme Encore M.2_2 Problem SSD not recognized
galer09
Hey Guys,
i need help. I bought a Samsung 980 Pro M.2 SSD
The M.2 SSD is installed in the M.2_2 slot but is not recognized in the BIOS and Windows. Same when i tryed to install dem on the DIMM.2 Module
I've tried all sorts of settings, but unfortunately nothing worked. I couldn't find anything on the internet that could help me either.
Mainboard: Asus Rampage VI Extreme Encore
CPU: Intel i9 10920x
4 REPLIES 4
tistou77
Hello,
Probably an option in the bios, I don't remember which one, I would have to look but not before tomorrow (if no one can look before)
Sorry for my english 😄
Case: Lian Li A77F
MB: Rampage VI Extreme Encore
CPU: i9 10980XE
RAM: G.Skill Trident Z RGB Royal 4x8Gb @4000 C16
GPU: EVGA RTX 2080ti XC Ultra
PSU: Seasonic Prime Ultra Titanium 1000W
OS: Intel Optane 905P PCIe
DATA: Samsung 980 Pro
SOUND: Asus Xonar Phoebus
Common problem.
In bios go to ADVANCED, select Onboard Devices Configuration, select CPU PCIE Configuration Mode, select Mode 2 to enable M.2_2 slot.
Save and reboot
Riicckk wrote:
Common problem.
Save and reboot
I did that, unfortunately it didn't help
I did that, unfortunately it didn't help. But there was one thing I hadn't tried, and that was I swapped the two SSDs from the place and that worked.
Idk why the 980 pro in the M.2_2 Slot not working...
But thanks for the help
Cherry_PL_
Level 11
Maybe it's about compatibility. I'm using 2x 970 PROs and they worked fine right after the computer was built and turned on for the first time with bios 0702.
