Results 1 to 7 of 7
Thread: GT-AXE16000 Upload speed Issues
10-06-2022 08:37 PM #1
- Join Date
- Sep 2022
- Reputation
- 10
- Posts
- 1
Can one of the groups responsible for propagating information related to issues update the site with the following:
Product: GT-AXE-16000 ROG gaming router
Firmware Version: 3.0.0.4.386_50168
*Case number N2207025636-001 Reported by reddit user
AI-Mesh Enable w/ 1 additional node using 1Gbps Ethernet backhaul *
**Issue:
* When performing a speed test, the upload speed is considerably less than expected. *In some aspects, near zero (0). *As found on a reddit forum, link found below. Updating the Channel settings appeared to have corrected the issue.
2.4 GHz
Channel Bandwidth 40MHz
Control Channel 6
Extension Channel Above
5GHz -1
**Channel Bandwidth 80MHz
Control Channel 36 Extension
Channel Above
5GHz -2 *
Control Channel Auto
Channel Auto
*https://www.reddit.com/r/ASUS/commen...s_work_around/
10-07-2022 05:06 AM #2
xeromist PC Specs Laptop (Model) Intel NUC laptop LAPQC71D Motherboard ROG Crosshair VIII Dark Hero Processor AMD 5800X Memory (part number) 32GB G.Skill Ripjaws V 3600 Graphics Card #1 ROG Strix RTX3090Ti Sound Card Sound Blaster Z Monitor AORUS FV43U Storage #1 Samsung 970 Pro 512GB CPU Cooler Custom loop Case BeQuiet Dark Base Pro 900 V2 Power Supply Corsair HX1000 Keyboard ROG Strix Flare II Animate Mouse ROG Chakram X Headset Steelseries Arctis Pro Wireless Mouse Pad ROG Scabbard Headset/Speakers Logitech z906 5.1 Network Router pfSense/OPNsense
- Join Date
- Jul 2010
- Reputation
- 436
- Posts
- 8,625
That user reported the WiFi changes did not help since they were using a wired connection. If you look at some of the other posts in that thread they ended up remapping some of the wired ports. I agree that all shouldn't be necessary but I think it's going to require a firmware update from ASUS to fix it.
* Support disease research with Folding@Home *
< < < Click the drop-down above my avatar for my PC specs!
10-16-2022 09:38 PM #3
- Join Date
- Jan 2014
- Reputation
- 10
- Posts
- 1
I too have this issue. ISP: Verizon FIOS 1gig service. When connecting directly to the ONT via ethernet, I get normal speeds. When i connect the ONT to the ASUS GT-AXE16000, i get terrible upload speeds...usually around 2Mbps, EVEN when connecting the computer to the router via ethernet. PLEASE LOOK INTO THIS AND RESOLVE ASAP. I am going to return this router if not resolved soon. This is simply not acceptable for a top tier product.
10-17-2022 05:06 AM #4
- Join Date
- Jul 2010
- Reputation
- 436
- Posts
- 8,625
I believe this model has a problem reporting feature in the web interface. I recommend submitting your logs there.
10-18-2022 12:20 PM #5
- Join Date
- Feb 2022
- Reputation
- 10
- Posts
- 326
Hmmm. I would like to help test if possible with new to us Frontier Fiber 1 G service. Finally got another damaged line replaced yesterday and it's up and running on the two Eero Pro 6s that they include in the monthly. My AXE16000 is the main router here, I would have to break down the network here to do so. (Kind of scared to do so, lest I have trouble reconfiguring it when I bring it back). Any advice on simplifying the process if I get the guts to try)? I know there's a backup function that I've never tried. Also I know very likely I'll need to open up a car cover and hood to reconfigure my IoT battery charger)...
10-25-2022 07:24 AM #6
- Join Date
- Feb 2022
- Reputation
- 10
- Posts
- 326
Could it be this:
https://www.snbforums.com/threads/ze...-speeds.80552/
11-05-2022 10:04 AM #7
[VoS]VIKING PC Specs Motherboard ROG MAXIMUS Z690 FORMULA Processor INTEL i9 12900KS Memory (part number) DOMINATOR® PLATINUM RGB 32GB DDR5 DRAM 6600MHz C32 Graphics Card #1 EVGA RTX 3080 TI Sound Card CREATIVE AE-5 Monitor ASUS 27" ROG Swift PG279QM Storage #1 Kingston Fury Renegade M.2 NVMe SSD Gen 4 2TB Storage #2 Kingston Fury Renegade M.2 NVMe SSD Gen 4 2TB Power Supply CORSAIR 1600i
- Join Date
- Apr 2013
- Reputation
- 10
- Posts
- 1
I had the same problem when installing my new GT-AXE16000.
I only got half the speed I should have and it worked just fine with my previous router ASUS RT-AX89X.
To solve the problem in my case, I installed the first firmware that is released and after that I did a factory hard reset.
Then I installed the last version of the firmware release 3.0.0.4.386.50168 and a new factory hard reset and now it works perfectly, I get the full speed of my internet connection.
