My current setup is as follows:
Ryzen 3900x
GSkill Trident Z RGB 3600 2x8GB
Powercolor Red Devil 6900 XT OC
I have been having a lot of issues with RGB software, so I decided to only run Asus software. I did a clean install of windows 11 and only installed Armory Crate and nothing else. I have a Thermaltake RGB controller on the 5v header at the top of the board which controls the LED strips along the case. The red devil card has a 5v 3 pin connector on it so the mobo can control the RGB. I connected the cable from the gpu to the 5v header at the bottom of the board. For some reason the lights on the gpu will flicker random colors on certain effects. Like solid colors seem to work fine, however any animated effects will cause random LEDS on the card to flash different colors. It also does it when not in windows, like during post and booting up. I made sure no other RGB software snuck its way in, and I didn't find anything. Any ideas on things I can try? Any help appreciated.
