Page 1 of 2 1 2 LastLast
Results 1 to 10 of 14
    ROG Guru: White Belt Array ExcessiveGBH's Avatar
    Jun 2013
    83
    Strix 4090 question about solid power light being on.
    Saw a reviewer on Youtube (4.10) Overclocked Asus Strix RTX 4090 Review w/ 5300 mhz i9 12900KS OC - YouTube @ 4.13 he mentions his power light was a solid on and said this was normal.
    Does anyone know if this is correct.
    System specs
    Win 11 Pro 21H2
    Rampage VI Extreme
    BIOS 3701
    I9 10920 @5.0GHz all cores
    EK-KIT G360 (CPU only)
    Samsung 960 PRO M.2 NVMe 1TB
    Samsung 970 EVO M.2 PLUS NVMe 2TB
    ADATA XPG S40G RGB M.2 NVMe 4TB
    1 Samsung SSD 4TB EVO
    1 X Samsung SSD 860 EVO 4TB
    2 x 10TB drives
    1 x 2TB drive
    ASUS ROG Strix GeForce RTX 4090 OC 24GB @2940 MHz
    32GB G Skill Trident Z 3466MHz 15-17-17-37
    Corsair AX1200W PSU
    Sound Denon AVC-A1
    LGC1 77
    ROG Member Array
    Apr 2013
    23
    I would suppose so mine had a red light on also when the computer is off but it turns off once you bootup, so should be fine.
    Jun 2013
    83
    Quote Originally Posted by blackforce View Post
    Ok... I have ordered mine, will arrive poss by Friday.
    System specs
    Win 11 Pro 21H2
    Rampage VI Extreme
    BIOS 3701
    2 x 10TB drives
    1 x 2TB drive
    Corsair AX1200W PSU
    Sound Denon AVC-A1
    LGC1 77
    ROG Member Array
    Apr 2013
    23
    ok nice great card. oh if you still are using that 1200 corsair power supply and guys have been saying the hx 1200 watt with this card it boots and just keeps looping so you may try it or get another one.
    ROG Guru: Yellow Belt Array Soupladel PC Specs
    Soupladel PC Specs
    Laptop (Model)Asus Stric G15 G512LV
    MotherboardAsos Crosshair X670E
    ProcessorAMD Ryzen 7950x
    Memory (part number)Corsair Dominator Platinum 6000 DDR5 2x16Gb (CMT32GX5M2X6000C36)
    Graphics Card #1Asus TUF 4090 OC
    MonitorAsus TUF VG27AQ1A
    Storage #1WD SN850X 2Tb
    CPU CoolerCorsair H170i Elite Cappelix
    CasePhanteks P600S
    Power SupplyCorsair HX1000
    Keyboard Razer Blackwidow Elite
    Mouse Razer Basilsk V2
    Headset Astro A50
    Mouse Pad Asus ROG Balteus
    OS Windows 10
    Network RouterAsus ROG AX1100
    Jul 2020
    151
    Is not the Strix Variant, but i have just put the 4090 Tuf OC in my build which includes a corsair HX1000 and i have had no issues so far under gaming loads or synthetic benchmarks
    Jun 2013
    83
    Quote Originally Posted by Soupladel View Post
    Maybe receiving my card today, my Corsair PSU is a AX1200 which is an earlier model, wonder if that has some bearing.
    System specs
    Win 11 Pro 21H2
    Rampage VI Extreme
    BIOS 3701
    2 x 10TB drives
    1 x 2TB drive
    Corsair AX1200W PSU
    Sound Denon AVC-A1
    LGC1 77
  7. #7
    ROG Guru: Yellow Belt Array Sprayingmango PC Specs
    Laptop (Model)2021 MacBook Pro M1
    MotherboardStrix Z690-E
    Processor12900K
    Memory (part number)32GB Corsair Dominator 5600 DDR5
    Graphics Card #1EVGA FTW3 Ultra 3090 Hybrid
    MonitorLG 48 C1, Asus PG27UQ, PG279Q
    Storage #1Samsung 970 Evo Plus 2TB NVME
    Storage #2Samsung 970 Evo 2TB NVME
    CPU CoolerCorsair H170i Capillex
    CaseCorsair 1000D
    Power SupplyCorsair AX1600i
    Keyboard Logitech G915
    Mouse Logitech G Pro Lightspeed
    Headset No...just no. Sennheiser HD650s
    Mouse Pad Logitech PowerPlay
    Headset/Speakers Denon 7.2 Atmos w/ Polk Signature Series
    OS Win10 Pro 20H2
    Network RouterAsus Rog Rapture AX11000 x4
    Mar 2013
    225
    The Power Detect LED functions as such: Solid On for NO power detected. Flashing Red for low power / inconsistent power detected. OFF = everything is fine.
    My Strix 4090 has a red light on when the PC is OFF. It turns off once I boot up.
  8. #8
    New ROGer Array
    Nov 2020
    1
    I had the same behavior, I think the reason why the LED is turned on after shutdown is due to the still active voltage at the PCIE port. The card detects voltage at the PCIE but no longer at the twelve-pin connector (600w pcie 5.0). To solve this problem you can activate ErP on your mainboard, so the components are no longer supplied with power after shutdown. I don't know what this function is called on the Asus mainboard, but google should help to find it out.
    Regards,
    Daniel
  9. #9
    Jun 2013
    83
    Had no issue with my AX1200 PSU. All booted up.
    Cheers.
    System specs
    Win 11 Pro 21H2
    Rampage VI Extreme
    BIOS 3701
    2 x 10TB drives
    1 x 2TB drive
    Corsair AX1200W PSU
    Sound Denon AVC-A1
    LGC1 77
  10. #10
    Administrator Array Silent Scone@ROG's Avatar
    Mar 2016
    265
    2,842
    Hello, install GPU Tweak III and disable Power Detect. The LED being lit when the system is off is normal.
