Hello everyone,*
I recently build a pc with the following specs:
**Mobo: Asus Strix Z-590A WIFI
CPU: Intel i7 11700K (with integrated graphics)
RAM: G.SKILL Trident Z Royal 32Gb(2x 16Gb) DDR4 3200*
SSD: Samsung 980 pro M.2 2280*
PSU: Lian li 750w
GPU: Zotac Rtx 3070ti Trinity*
I installed windows 11 and updated the BIOS to the latest version. When I start the pc, it doesn’t boot into windows if the display port is connected to the GPU, it turns on but windows never loads and the monitor stays idle. The pc boots normally into windows only if I turn off the pc and connect the display port to the motherboard and turn the pc back on. If the pc remains on and if I disconnect the display port from the motherboard and connect it into the GPU, it works fine. If I restart the pc with the cable still connected to the GPU, the pc doesn’t boot into windows and the problem remains. I tried connecting the GPU to a different PCI-e slot and that didn’t help. Any thoughts?
Please help ✌️*
