Results 1 to 7 of 7
    ROG Guru: Yellow Belt Array Soupladel PC Specs
    Soupladel PC Specs
    Laptop (Model)Asus Stric G15 G512LV
    MotherboardAsos Crosshair X670E
    ProcessorAMD Ryzen 7950x
    Memory (part number)Corsair Dominator Platinum 6000 DDR5 2x16Gb (CMT32GX5M2X6000C36)
    Graphics Card #1Asus TUF 4090 OC
    MonitorAsus TUF VG27AQ1A
    Storage #1WD SN850X 2Tb
    CPU CoolerCorsair H170i Elite Cappelix
    CasePhanteks P600S
    Power SupplyCorsair HX1000
    Keyboard Razer Blackwidow Elite
    Mouse Razer Basilsk V2
    Headset Astro A50
    Mouse Pad Asus ROG Balteus
    OS Windows 10
    Network RouterAsus ROG AX1100
    Jul 2020
    151
    4090 TUF OC Coil whine under load
    So i have just put the aforementioned GPU in my system, hooked it up with 4x8 PIN PCIE connectors via the adaptor supplied with it and under any sort of load, there is a very loud coil whine audible over game audio.
    At first i thought it was due to the fact i was doing initial testing after installation and the case side panel was off, but even with the panel on, the noise is still audible over audio during games and synthetic benchmarks.
    Anyone else Experienced this?
    Is it something that might be fixed with a vbios update, or have i got a card that is perhaps a bit of a lemon?
    ROG Guru: Yellow Belt Array Asryan PC Specs
    Asryan PC Specs
    MotherboardROG Crosshair VIII Dark Hero
    Processor5900x
    Memory (part number)32GB G.SKILL Trident Z RGB / 3466Mhz
    Graphics Card #1EVGA RTX 3090 STRIX 0c
    Monitorlg 38gn950-b
    Storage #1Sabrent Rocket
    Storage #2SSD: Samsung EVO 850 - 250Go + Samsung EVO 850 - 500Go
    CPU CoolerEK AIO 360 RGB
    CasePhanteks P600S
    Power SupplySeasonic Prime TX 1000 Titanium
    Keyboard Asus Claymore 2
    Mouse Logitech G903 Chaos Spectrum
    Headset SteelSeries Pro Wireless
    Headset/Speakers G560 Logitech
    OS Win 10 pro
    Oct 2016
    14
    244
    I have the same issue on the same card..
    https://www.youtube.com/watch?v=TQU6-ILFX5Q
    It's been years i haven't been lucky with this, all my previous cards had coil whine; and it sucks even more on this one since the temperatures are gread and so the fans are quite silent in game and so all i can hear is this
    Soupladel PC Specs
    CasePhanteks P600S
    Headset Astro A50
    OS Windows 10
    Jul 2020
    151
    Quote Originally Posted by Asryan View Post
    i don't really do productivity work but i have found a solution, or perhaps its more of a workaround than a solution for the issue in gaming, now i know there are probably people that are going to say "duh! obviously" here but i have never really had to deal with coil whine before so never really paid attention to videos or articles talking about it. However, i have found that if i cap the frame rate, even at something obscenely high like 240fps, it all but eliminates the coil whine and as my displays doesnt do higher than 144hz without enabling overclocking, its not really going to lose me anything by capping the frames
    TeamROG Moderator Array xeromist PC Specs
    xeromist PC Specs
    Laptop (Model)Intel NUC laptop LAPQC71D
    ProcessorAMD 5800X
    Memory (part number)32GB G.Skill Ripjaws V 3600
    Graphics Card #1ROG Strix RTX3090Ti
    Sound CardSound Blaster Z
    MonitorAORUS FV43U
    Storage #1Samsung 970 Pro 512GB
    CPU CoolerCustom loop
    CaseBeQuiet Dark Base Pro 900 V2
    Keyboard ROG Strix Flare II Animate
    Mouse ROG Chakram X
    Headset Steelseries Arctis Pro Wireless
    Mouse Pad ROG Scabbard
    Headset/Speakers Logitech z906 5.1
    Network RouterpfSense/OPNsense
    xeromist's Avatar
    Jul 2010
    436
    8,615
    It's also worth noting that coil whine can be affected by power supply. So for Asryan's situation, if the same power supply is reused, that could be the culprit.
    * Support disease research with Folding@Home *
    < < < Click the drop-down above my avatar for my PC specs!
    Asryan PC Specs
    Processor5900x
    Monitorlg 38gn950-b
    CasePhanteks P600S
    OS Win 10 pro
    Oct 2016
    14
    244
    Quote Originally Posted by Soupladel View Post
    I tried capping fps, didn't seemd to help.
    Quote Originally Posted by xeromist View Post
    Yep same one. I had the same issue on my strix 3090. I've tried with to a thor a some point in the past same issue but seasonic and thor are quite the same..
    Administrator Array Silent Scone@ROG's Avatar
    Mar 2016
    265
    2,833
    "Coil" whine or inductor noise is a natural phenomenon.
    1) PSUs produce their own coil whine. How much depends on the quality, type, specs, and size of the components used.
    2) The graphics card also produces some coil whine. Again, how much depends on the quality, type, specs, and size of the components used.
    3) Interaction between the PSU and graphics card can result in louder coil whine.
    4) Coil whine is related to frequency and current.
    5) Rapid changes in current demands (such as rapid load modulation when transitioning from low power state) is a major contributor to piezoelectric noise (some capacitor types are more prone to this).
    6) As ripple frequency and other sources of power-related noise can impact the level of coil whine, some combinations of PSU and graphics cards may exhibit more noise than others. For a vendor, it is very difficult to account for all permutations because the cost is a factor if you want to increase resilience to coil whine. There is only so much a vendor will or can do.
    7) As current plays a part, the amount of audible whine will vary from system to system.
  7. #7
    ROG Member Array
    Jan 2019
    3
    16
    IDK About your 4090, but my last 2 Asus cards both had it my Tuf 3090 OC, and 2080Ti Strix OC.
    My NEW Gigabyte 4090 OC Doesn't have one bit of coil whine.
    I am using Seasonic 1000W power supply.
    This is an Asus issue, and honestly unacceptable for that cost.
