Results 1 to 10 of 11
11-06-2022 01:05 PM #1
homdax PC Specs Motherboard Asus TUF B450-Pro Gaming Processor AMD Ryzen 7 5800X Memory (part number) 32 GB Kingston KHX3200C Graphics Card #1 ASUS TUF Gaming X3 Radeon™ RX 5600 XT EVO Monitor 2 x Dell U2718Q 4K Storage #1 NVME CPU Cooler AMD Wraith Keyboard Logitech G815 Mouse Logitech G703 Mouse Pad None Headset/Speakers Creative OS Windws 11 Pro Network Router IPFire custom SuperMicro
- Join Date
- Mar 2018
- Reputation
- 23
- Posts
- 32
RAM speed decrease after CPU upgrade
Motherboard is TUF B450M-Pro Gaming
RAM sticks are 2 x Kingston KHX3200C16D4/16GX
CPU is Ryzen 7 5800X
BIOS is 3802 which I think is the latest available.
I am used to not being able to get above 3200MHz on the memory frequency, but now I am not even getting 3000 using D.O.C.P standard profiles.
Did set BIOS to default after the CPU upgrade and started from there. Only tried different D.O.C.P so far.
Anyone has any ideas on where to start changing settings... ?
11-06-2022 02:23 PM #2
- Join Date
- Mar 2018
- Reputation
- 23
- Posts
- 32
11-07-2022 12:54 AM #3
geneo PC Specs Laptop (Model) 13" Macbook Pro M1 Motherboard ROG Maximus XIII Hero (WiFi) Processor i9-10900k 5.2 GHz AVX0 all core, 1.28v Memory (part number) 64 GB G.Skill TridentZ RGB 4200 @ CL18 Graphics Card #1 Asus ROG Strix 2070 Super A8G Sound Card On-board Monitor EIZO Coloredge CG2730 and Viewsonic QHD displays Storage #1 Hynix 2TB P43, WDC SN850 1TB, Samsung 980 1TB Storage #2 1TB 850 x 1 TB 860 EVO RAID0, 6 TB WDC Black, 6TB IronWolf Pro CPU Cooler EK-AIO 360 D-RGB w/Phanteks T30 -120 fans, 1 Noctua Chromax 140 case fan Case Fractal Design Meshify 2 dark tint Power Supply 750W Seasonic Prime Ultra Titanium Plus Keyboard Glorious GMMK TKL Mouse Logitech G305 Headset Bose QC15 Headset/Speakers Vanatoo T1, Klipsch R-12SWi Sub OS Windows 11 Pro X64, 22H2 Network Router Asus RT-AX82U + RT-AX86S mesh Accessory #1 Logitech c920e webcam Accessory #2 Sabrent DS-SC5B 5-Bay USB-C HDD docking station Accessory #3 xrite i1 Display monitor calibration
- Join Date
- Feb 2014
- Reputation
- 115
- Posts
- 672
It may be that you just got a processor with a weaker memory controller, which sucks if so. Hope not but have no suggestions.
11-07-2022 07:43 AM #4
- Join Date
- Mar 2018
- Reputation
- 23
- Posts
- 32
ok? Never heard of that in my 30 years building computers. How would I diagnose it, because if the CPU is flawed it is an obvious RMA...
11-07-2022 07:53 AM #5
- Join Date
- Aug 2019
- Reputation
- 10
- Posts
- 12
by any chance did you check your ram in zentimings ?
btw do u have an AMD GPU ? if yes and your zentimmings are incorrect go to task scheduler and disable "AMDRyzenMasterSDKTask" that fixed all my problems with rams
11-07-2022 08:31 AM #6
- Join Date
- Mar 2018
- Reputation
- 23
- Posts
- 32
dangerbass
No, I did not, are you referring to this: https://zentimings.protonrom.com/ ?
I do have an AMD GPU, specifically an RX 5600 GT.
I do not have Radeon Software installed, but drivers "only" since the Radeon Software has a tendency to crash some games.
Can't find any task for "AMDRyzenMasterSDKTask". Is that not a Ryzen Master dependent task, I don't have Ryzen Master installed.
Open for suggestion, should I do the Zentimings thing? Is that the correct source?Last edited by homdax; 11-07-2022 at 08:35 AM.
11-07-2022 09:24 AM #7
- Join Date
- Mar 2018
- Reputation
- 23
- Posts
- 32
11-09-2022 07:13 AM #8
- Join Date
- Mar 2018
- Reputation
- 23
- Posts
- 32
Any ideas on how to proceed with this?
11-11-2022 06:23 AM #9
xeromist PC Specs Laptop (Model) Intel NUC laptop LAPQC71D Motherboard ROG Crosshair VIII Dark Hero Processor AMD 5800X Memory (part number) 32GB G.Skill Ripjaws V 3600 Graphics Card #1 ROG Strix RTX3090Ti Sound Card Sound Blaster Z Monitor AORUS FV43U Storage #1 Samsung 970 Pro 512GB CPU Cooler Custom loop Case BeQuiet Dark Base Pro 900 V2 Power Supply Corsair HX1000 Keyboard ROG Strix Flare II Animate Mouse ROG Chakram X Headset Steelseries Arctis Pro Wireless Mouse Pad ROG Scabbard Headset/Speakers Logitech z906 5.1 Network Router pfSense/OPNsense
- Join Date
- Jul 2010
- Reputation
- 436
- Posts
- 8,625
The best thing would be to compare the timings with the old & new CPU. See if for some reason you are getting odd timings with the new CPU. Also, if you note the timings with the old CPU and manually set them for the new CPU you can make a direct comparison. If everything is the same and somehow it is not working on the new CPU then that would indicate the weak IMC previously mentioned.
Also, if you have been building for 30 years then having the Integrated Memory Controller on the CPU die is a more recent architecture that didn't exist when you started. Intel started doing it with the Nehalem generation of CPUs (2008).* Support disease research with Folding@Home *
< < < Click the drop-down above my avatar for my PC specs!
11-11-2022 08:19 AM #10
- Join Date
- Mar 2018
- Reputation
- 23
- Posts
- 32
Lol, yeah, experience does not equal excellence..
I can't really swap the CPU's back and forth. The old CPU is in another rig as an upgrade from a Ryzen 1600 ...
This may come as a surprise but I am actually expecting Asus or someone to provide me with the correct BIOS settings to make this work, because there must be such a thing, right? It can't be anyones best guess?
