Results 1 to 9 of 9
11-07-2022 08:18 PM #1
- Join Date
- Jan 2021
- Reputation
- 10
- Posts
- 4
Z690 Formula - 13900kf - DDR5 7600mhz Issues ( Detect Memory)
Hi there everyone, after updating my system from 12900ks + 6400mhz cl34 sticks to 1300kf + 32gb 7600mhz cl36 kit none of the xmp profiles or cpu overclock seettings seem to work and i just get Detect Memory error on the mainbord with black screen. Pc is only able to start with the optimized default settings in bios. One of my friend with 13700k is having the exact same issue. Has anyone been experiencing these with the z690 boards?
Any tips would be welcome
11-08-2022 03:49 AM #2
- Join Date
- Apr 2018
- Reputation
- 10
- Posts
- 27
I think the problem is that z690 does not support 7600mhz overclocking, only up to 6600mhz
11-08-2022 04:34 AM #3
Hello,
You will need to tune manually. 7600MT needs a 13th gen board and a decent CPU (strong IMC). *Depending on the board, you can try 6600 - 6800MT / 1.42v VDD / VDDQ. Alternatively return the kit for one present on the motherboard QVL.Last edited by Silent Scone@ROG; 11-08-2022 at 04:39 AM.
11-08-2022 02:38 PM #4
Ultrasonix PC Specs Laptop (Model) GX703HS Motherboard Maximus Z690 Glacial £2300 Processor 12900ks @5.8hz Memory (part number) Corsair Platinum DDR5 32GB CL32 Graphics Card #1 3090Ti FE Graphics Card #2 3090TI FE Monitor Asus 34" ultra wide IPS Storage #1 4TB ssd backup Storage #2 4TB ssd backup games CPU Cooler Glacial Case phanteks Ethoo Elite Black Power Supply Corsair HX1600I Keyboard Asus Claymore Mouse Asus Spartha Headset Asus Centurian OS Windows 11 22h2 Accessory #3 2 X water cooling loops with 8X 460 coolers 8 fans per cooler
- Join Date
- Apr 2018
- Reputation
- 10
- Posts
- 7
hi there im runing memory on the QVL list Gskill 6400 CL32 and my maximus z690 Glacial wont get back detect memory what the hell is going on. here.
11-08-2022 02:42 PM #5
- Join Date
- Apr 2018
- Reputation
- 10
- Posts
- 7
My motherboard what happy running 5600 cl32 i upgraded to Gskill ARGB memory nice looking and now all i get is Detecting memory in XMP 1 and XMP 2 neither work and im very unhappy with QVL checking if this wont work ..
anyone else having the same issue and what was your fix. please.
11-08-2022 03:15 PM #6
- Join Date
- Jan 2021
- Reputation
- 10
- Posts
- 4
Wasn’t the ram frequencies gonna be updated for 13th gen cpus on the z690 boards? One of my friends with Msi z690 board is using 7600mhz succesfully with a bios update only.
*I don’t think this issue is related with z790 upgrade but the bios stability. Since there are people with z790 boards having the similar issues i do not wish to upgrade my board without an official response from asus.
11-08-2022 03:20 PM #7
- Join Date
- Jan 2021
- Reputation
- 10
- Posts
- 4
11-10-2022 09:58 AM #8
- Join Date
- Jun 2022
- Reputation
- 10
- Posts
- 14
You'll never make it past the memory training if all you did was select the XMP profile and then change the frequency to 7600. You'll need to change a couple voltages for stability, and you'll most likely need to loosen the timings a little bit. Also, the z690 boards aren't made to support that frequency, I don't know if you'll ever get that to post, but I am almost certain you'll blue screen.
As far as your friend, you can certainly get the system to post with that kit installed, however you won't be able to run it at full speed. Ask your friend to send you a screen shot of the CPUz or memtweakit. I can promise you he isn't running that at 7600. Check out Buildzoid on YouTube. I think his channel is Actually Hardcore Overclocking or something like that. He has a lot of videos that you help you understand what exactly is possible. He has a couple in on Asus boards and if I remember correctly he has one at 6600 which I think is the highest Asus z690 will go.
If you want it to post, XMP 1. then lower the frequency to 6600. Also, if you have undervolted your 12th gen CPU you'll need to switch that back to auto... but probably manual and add a little voltage.
11-19-2022 01:23 PM #9
- Join Date
- Oct 2020
- Reputation
- 10
- Posts
- 4
I successfully got my gskill ddr5 7600mhz cl36 kit (F5-7600J3646G16GX2-TZ5RK) running at 7200 mhz cl34 @ 1.40v Stable on my asus z690 formula with a 13900KF.
