Results 11 to 20 of 34
11-15-2022 11:22 PM #11
- Join Date
- Jul 2019
- Reputation
- 14
- Posts
- 20
11-16-2022 12:31 AM #12
- Join Date
- Feb 2012
- Reputation
- 10
- Posts
- 149
On mw2. I'm using an aio rog ryujin II cpu cooler. My case is a lian li O11 case with 9 case fans. I'm probably going to undervolt the cpu, since I can't stand the noise.
z790 maximus hero
13900k intel
4090 geforce
tforce 7200 ddr5
11-16-2022 12:43 AM #13
- Join Date
- Oct 2018
- Reputation
- 10
- Posts
- 8
try remount the aio cpu block, possible it got bad contact and while at it get this first https://a.co/d/1jw89tV will gain usually 2-5 degrees as stock retainer like bend a bit cpu ihs
11-16-2022 01:06 AM #14
JohnAb PC Specs Laptop (Model) HP 430 G5 Motherboard ASUS Maximus Z690 Hero Processor 12900K Memory (part number) 2x 16GB CMK32GX5M2B5200C40 Graphics Card #1 ASUS RTX 3090 TI 24GB TUF GAMING OC - TUF-RTX3090TI-O24G-GAMING Monitor 28" Samsung 4K & 32" Samsung 4K Storage #1 3x NVME Drives on Motherboard Storage #2 2x SATA HDD, 2x SATA SSD CPU Cooler Corsair iCUE H150i ELITE LCD Display 360mm RGB Liquid CPU Cooler Case Corsair 7000X RGB Black Full Tower Power Supply Corsair RM1000x Keyboard SteelSeries Apex Pro Mouse SteelSeries Rival 600 Headset Blue Yeti / Sundara Headphones Headset/Speakers Bose Soundbar OS Win 11 Pro Network Router Netgear Nighthawk RAXE500 6E Accessory #1 SDR Radio Accessory #2 Graphics Tablet Accessory #3 Jabra Microphone/Speaker
- Join Date
- Jun 2022
- Reputation
- 84
- Posts
- 496
That seems very high for the CPU temp playing MW2. I have the 12900K, but when I play MW2 on 50% GPU power (using MSI Afterburner) I get 100 fps and the CPU never goes much above 50C. If I run the GPU on full power, I get an average 160 fps and the CPU hovers around 55C, 60C max.
I have MCE and XMPI on and just about about all other BIOS settings are on default. Perhaps the cooler does need re-mounting or you have an airlock in the water loop? Try rotating the case around a few times, ideally with the pump running if you can. If it's an airlock, that might clear it.
Another thought - do you have the AIO cooler below the highest point of the radiator with the tubes going up straight up? That's the best way to ensure that air never gets trapped. You'll find some YouTube videos that show the best way to mount an AIO. Maybe worth checking?Last edited by JohnAb; 11-16-2022 at 01:13 AM.
Z690 Hero, BIOS 2204, ME Firmware 16.1.25.2020, Corsair 7000X Case, i9 12900K, ASUS TUF OC 3090TI, 2 x 16GB Corsair RAM @ 5200MHz, Windows 11 Pro 22H2, Corsair H150i AIO Cooler, 4x Corsair RGB case fans, 3x M.2 NVME drives on motherboard, 2x SATA SSDs, 2x SATA HDs, 2x 4K monitors.
"If you're lazy like me and do nothing else in life, be nice to yourself and back up your data today"
11-16-2022 07:06 AM #15
Bukov. PC Specs Motherboard ASUS RoG Strix Z790-E Gaming Wifi Processor Intel i9-13900K Raptor Lake Memory (part number) CMT32GX5M2X6200C36 (16x2) Graphics Card #1 Gigabyte 4090 Gaming OC Monitor LG Ultragear 27gp850 2k @ 180hz Storage #1 WD sn850x 2tb Storage #2 WD sn850x 2tb CPU Cooler Lian Li Galahad 360 Infinity-fan Case Lian Li 011D-XL-RoG + 10x Lian Li Infinity fan Power Supply Corsair HX 1200 80+ Platinum Keyboard Steelseries Apex 7 (red switches) Mouse Razor Lancehead TE Headset Sennheiser HD 569 Mouse Pad iCEMAT Headset/Speakers Logitech Z901 5.1 OS Yes Network Router Skynet beta 0.97 Accessory #1 Valve Index Accessory #2 Tobii Eye/Head tracker Accessory #3 Xbox controller
- Join Date
- Nov 2022
- Reputation
- 10
- Posts
- 14
11-16-2022 06:32 PM #16
- Join Date
- Feb 2012
- Reputation
- 10
- Posts
- 149
Yes It was a bad mount. But I still get core thermal throttling using cinebench at stock settings. I’m getting the frame anti bending and see if it helps.*
z790 maximus hero
13900k intel
4090 geforce
tforce 7200 ddr5
11-17-2022 02:27 AM #17
- Join Date
- Oct 2018
- Reputation
- 10
- Posts
- 8
Then look this guide https://www.overclock.net/threads/as...nners.1801569/ first part is jsut notions but you want do the part where let you reduce a lot vcore voltage under load , i am now runing 1.21 without any problem in cinebench and temps at 70, 40k+ score, search in the thread "But we want to UNDERVOLT the CPU, right?" that the part you want
11-17-2022 04:26 AM #18
- Join Date
- Feb 2012
- Reputation
- 10
- Posts
- 149
z790 maximus hero
13900k intel
4090 geforce
tforce 7200 ddr5
11-17-2022 06:09 AM #19
Hello,
Did you repaste the CPU?
I’d recommend using the thermal Grizzly frame first and report back.*
11-17-2022 10:29 AM #20
- Join Date
- Oct 2018
- Reputation
- 10
- Posts
- 8
