Results 1 to 6 of 6
    ROG Guru: Blue Belt Array martin_metal_88's Avatar
    Apr 2010
    777
    Single slot 460? Yes! it work!
    When XFX released the firstHD5670 single slot, many people were sure it wouldn't work. But it was great. Now KFA2 is trying to score on a GTX460 featuring DP + 1 DVI and a single slot full body cooler! Guess what, IT WORK!
    I was myself expecting terrible noise and temp from this idea, but according to this GURU3D review it's not that bad. With a single DVI and a DP, this card would be a perfect match for a mid system running a single screen, for folding system or for gaming HTPC!
    Will Asus enter the game?
    Article here :
    http://www.guru3d.com/article/kfa2-g...-razor-review/
    Martin_metal_88
    Colenzo :Coolermaster ATCS 840 | Gigabyte's EP55-UD5 | Intel Core I7 860 @ 3.8Ghz | 4GB G.skill Trident 1600 | MSI GTX460 1GB HAWK Twin frozr | WD 640 black + WD 1TB green + WD 1TB Blue | Pionner DVR-216 | Silverstone Strider Plus 850W | Coolermaster Hyper 212 plus in push pull fan config |
    Ask for more!
    Brian@ASUS
    Guest
    neat idea, but im not a big fan. looks beefier with a 2 slot config. if you see our upcoming DirectCu2 design, we are actually going 3 slot (2.5 physical card) its just beefier
    TeamROG Moderator Array xeromist PC Specs
    xeromist PC Specs
    Laptop (Model)Dell Inspiron 15 7567
    MotherboardMSI x470 Gaming Plus
    ProcessorAMD 2600X
    Memory (part number)16GB Crucial Ballistix Elite 3600
    Graphics Card #1ASUS GTX 1080 Strix
    MonitorBenQ BL3200PT
    Storage #1Intel 600p NVMe
    CPU CoolerWraith
    Casecustom Antec 900
    Power SupplyCorsair HX1000
    Keyboard Logitech Orion Spark
    Mouse Logitech MX500
    Headset Plantronics 777 with Oregon Aero upgrade
    xeromist's Avatar
    Jul 2010
    309
    7,670
    Did you just dis a unique design because it wasn't big enough? *sigh* It's no wonder enthusiasts have to beg and plead to get new SFF parts.
    * Support disease research with Folding@Home *
    < < < Click the drop-down above my avatar for my PC specs!
    Shade Soul13
    Guest
    I'd just shell out the money for 2 or 3 slots. I'd be paranoid about the smaller space generating more heat, personally.
    xeromist PC Specs
    ProcessorAMD 2600X
    CPU CoolerWraith
    xeromist's Avatar
    Jul 2010
    309
    7,670
    I'm not really worried about the cost so much. I like to build a compact systems that are very portable and perform well. I've been moving to progressively smaller cases with each of my last builds and I want to go smaller. It doesn't have to be top of the line but it needs to be decent.
    And you don't really worry about heat with an appropriate design. As long as the heat is going out of the case then it doesn't really matter how you achieve it.
    Six Foot Ginger
    Guest
    i really like the one slot designs, I'll take one
Similar Threads
  1. TiTON's ROG Case Mod Work Log
    By TiTON in forum Case Modding & PC Builds
    Last Post: 02-28-2013, 07:03 PM
  2. ASUS Combines Killer NIC and Xonar Audio into Single Addon Card
    By ottoyu34 in forum Overclocking & Tweaking
    Last Post: 08-26-2011, 12:07 PM
  3. Best PCIE slot for OCZ Revo on P8P67 Deluxe board
    By shotosan in forum Other Series Motherboards
    Last Post: 01-15-2011, 05:25 AM
  4. Replies: 3
    Last Post: 12-09-2010, 08:39 PM
