Page 1 of 2 1 2 LastLast
Results 1 to 10 of 12
    New ROGer Array Ily3ss59 PC Specs
    Ily3ss59 PC Specs
    MotherboardROG MAXIMUS Z690 EXTREME (BIOS 2204)
    ProcessorIntel Core i9 12900K
    Memory (part number)DDR5 G.Skill Trident Z5 RGB 64 Go (2 x 32 Go) 6000 MHz CL30 (F5-6000J3040G32GX2-TZ5RK)
    Graphics Card #1MSI SUPRIM X 4090
    Sound CardCreative SB AE9
    MonitorASUS ROG PG43UQ
    Storage #1Samsung M.2 970 EVO 2TB
    CPU CoolerNZXT Kraken Z73
    CaseNZXT H7 Elite
    Power SupplyCorsair AX1600i
    Keyboard Corsair K100 RGB
    Mouse Corsair Dark Core Pro SE
    Headset Beyerdynamic MMX 300
    Headset/Speakers Logitech Z906
    OS Windows 11 22H2
    Jun 2020
    12
    ROG MAXIMUS Z690 EXTREME + DDR5 G.Skill Trident Z5 6000 MHz UNSTABLE XMP
    MOTHERBOARD : ROG MAXIMUS Z690 EXTREME (BIOS V2103)
    CPU : i9 12900k
    DRAM : G.Skill Trident Z5 RGB 64 Go (2 x 32 Go) DDR5 6000 MHz CL30 (F5-6000J3040G32GX2-TZ5RK)
    Hello everyone I got my new RAM and the problem is when I activate the XMP windows freeze after a few minutes I tried the XMP 1 AND 2 I need help thank you
    ROG Member Array
    Feb 2014
    7
    Hello,
    This memory kit is on QVL list of your mainboard as mine (Z690-F) and I was considering to buy it, too. It's weird but I've read 3-4 people having problem with this memory kit on Asus Z690 series mainboards.
    Do you have a stable manual configuration for this memory kit @4800Mhz or may be even more?
    Ily3ss59 PC Specs
    CaseNZXT H7 Elite
    OS Windows 11 22H2
    Jun 2020
    12
    no I haven't tried in 4800 but I don't want to know it's in the QVL list it must work in 6000 otherwise why make a QVL list?
    ROG Member Array
    Feb 2014
    7
    I completely aggree with u But I think you should be sure if your memory kit is working, that's why i suggest you trying to make it work at lower speeds. If it still fails, memory kit can be defective. If not, it will be Asus mainboard's fault at the end since this is a QVL kit which says this kit is tested at 6000Mhz on this board.
    New ROGer Array simon.leueuer PC Specs
    MotherboardASUS Maximus Z690 Extreme
    ProcessorIntel i9 12900K
    Memory (part number)G.Skill Trident Z RGB, DDR5, 2 x 32GB, CL30, 6000 MHz
    Graphics Card #1ASUS GeForce ROG STRIX RTX 3080 Ti O12G-Gaming
    Monitor3x Acer Nitro XV273KP, 4K , 27 "
    Storage #1Samsung 980 Pro, 2000 GB, M.2
    Storage #2Samsung 980 Pro, 2000 GB, M.2
    CPU CoolerASUS WAK ROG Strix LC II 360 ARGB
    CaseLian-Li O11Dynamic XL ROG
    Power Supplybe quiet! Dark Power Pro 11, 1200 W
    Keyboard Logitech G915 LIGHTSPEED, Wireless, Mechanical
    Mouse Logitech G903 Lightspeed
    Headset SteelSeries Arctis Pro Wireless
    Mouse Pad Logitech G Powerplay
    OS Windows 11 Pro, 22H2, 22621
    Network RouterASUS RT-AC5300 ROG
    Dec 2021
    40
    21
    Hello everyone
    I have the exact same Setup like ILY3SS59:
    CPU : i9 12900k
    First I had the Kingston Fury Beast 32 Go (2 x 16 Go) DDR5 5200 MHZ CL40. It worked with XMP I without problem.
    After a few Months i changed to the mentioned new G.Skill DDR5.
    I used XMP I and it worked since day 1 without a freeze, slowdown or any problem.
    Maybe a faulty Ram-Bank on the motherboard or a faulty Memory Stick?
    I had BIOS 2103 on it and NOT reseted settings after change of the RAM
    Hope it helps. If u (or other user) have specific questions to the setup or settings,
    dont hesitate to contact me directly or via reply here in this thread
    Ily3ss59 PC Specs
    CaseNZXT H7 Elite
    OS Windows 11 22H2
    Jun 2020
    12
    Quote Originally Posted by buyukbang View Post
    Ok thank you for your answer how do I test at lower speed? do you have a tutorial or something?
    EDIT : Sorry I just noticed that I was not in BIOS version 2103 but on BIOS BETA version 2203 I just went back to version 2103 I activated XMP 1 I'll come back to you if that solved the problem thank you for your feedback.
  7. #7
    ROG Member Array
    Feb 2014
    7
    Hey Simon,
    Thank for the reply. I'm also trying to make a buying decision between Gskill 64gb 6000Mhz or Gskill 32gb 6600Mhz, both are on QVL. Have you had a chance to run this kit at and higher frequency as stable?
    Quote Originally Posted by simon.leueuer View Post
    Hello everyone
    CPU : i9 12900k
  8. #8
    ROG Member Array
    Feb 2014
    7
    Quote Originally Posted by Ily3ss59 View Post
    I think you should thank to Simon, since he gave that useful input. I'm also waiting to your result, good luck!
  9. #9
    Nate152 PC Specs
    MotherboardROG Strix Z690-F Gaming WiFi
    Processori7-12700KF
    Memory (part number)Kingston Fury Beast 16GB (2x8GB) 6000MT/s (KF560C40BBK2-16)
    Graphics Card #1ROG Strix 3090 Ti LC OC
    Sound CardROG SupremeFX
    MonitorHP ZR30w
    Storage #1Seagate Firecuda 530 1TB
    CPU CoolerEK Quantum Velocity2
    CaseThermaltake Tower 900
    Power SupplyEVGA Supernova 1600 T2
    Keyboard ROG Falchion NX / Strix Flare II/Azoth
    Mouse ROG Chakram X/Chakram Core/Spatha X/Harpe Ace
    Headset ROG Delta S Animate
    Mouse Pad Steelseries Prism XL / ROG Scabbard II/Hone Ace
    OS Windows 11 Home
    Accessory #1 2x Swiftech Maelstrom X300 D5 V2
    Accessory #2 2x Hardware Labs SR2 560 MP radiators
    Accessory #3 Lamptron FC-5 V3 fan controller
    Nate152's Avatar
    Feb 2013
    408
    17,903
    Hi lly3ss59,
    Let us know if your ram is stable after the bios update.
    If it's not stable after the bios update, 64GB 6000MHz cl30 might need some voltage tuning.
    These five voltages can help with memory stability.
    Dram VDD
    Dram VDDQ
    CPU System Agent
    IVR Transmitter VDDQ
    Memory Controller
    Your memory is rated at 1.40v so X.M.P. should be setting
    Dram VDD: 1.40v
    Dram VDDQ: 1.40v
    In the bios on the extreme tweaker page, try raising these voltages..
    CPU System Agent voltage: 1.20v - 1.25v (up to 1.35v if needed)
    At the bottom of the extreme tweaker page you should see Advanced Memory voltages.
    IVR Transmitter VDDQ: 1.40v
    Memory Controller: 1.20v - 1.25v (up to 1.35v if needed)
    At the top of the Dram Timing Control Page select Maximus Tweak Mode 2, this also helps with memory overclocking.
  10. #10
    Dec 2021
    40
    21
    Hi Buyukbang
    Hello Everyone
    I was able to run a G.Skill Trident Z5 RGB 2 x 16GB, 6400 MHz, DDR5, CL32 under XMP I as stable thru benchs (FFXIV Bench 6.0 - 4K Max)
    No tweaks / no changes in OC manually (like voltage, etc.).
    Important to say, that I tested under Bios 2103 and that I never tried out XMP II (since it worked flawlessly under XMP I).
    My decision was based on my needs aka better results on the game I play. The winner was CLEARLY the G.Skill Trident Z5 RGB 2 x 32GB, 6000 MHz, DDR5, CL30.
    For my needs CL30 to CL32 > 6000Mhz to 6400Mhz & surely 64GB > 32GB.
    Hope that helped on ur decision.
    BTW:
    Officially the ROG MAXIMUS Z690 Extreme supports 6400 Mhz native from scratch. Higher ones like 6600 Mhz are either new tested on a Z690
    or more of a gamble based on a general list from Intel.
    Have all a good day and stay safe ^^
