ROG Strix Arion Enclosure (NVME) Not showing up on Desktop - Rampage IV Extreme
dbit
I purchased a new Micron NVME drive and put it into a ROG Strix Arion enclosure (to match my 2022 Zephyrus).
Unfortunately when I plug the drive into my rampage iv extreme machine, absolutely nothing happens. The drive shows up on all of my other desktops and laptops. I updated the BIOS, did the CAP conversion, updated to the most recent BIOS, tried to installed the latest USB 3 drivers available on the asus site (although nothing visible happened when I launched the setup other uses said that behavior is normal), went into the BIOS and enabled all the USB 3.0 options avalable there, still no dice!
I don't see any USB mass storage driver load up. I don't even see the 'eject' option to eject the drive. The lights come on but it's like nothing happens!
Any thoughts on what might be going on here?
xeromist
I would check device manager to see if anything is flagged with a warning. Also, you could check the Disk Management panel in Windows but if the device driver isn't loading you won't see it there.
