Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 21
    ROG Member Array
    Jun 2020
    13
    Rog X670 Extreme Build, Computer boots when UPS is turned on before power button
    I have the following build:
    MB: ASUS X670 Extreme
    CPU: AMD x7950
    Memory: 64GB G.Skill 6000 Neo
    GPU: ASUS Tuf 4080 OC
    PSU: Corsair 1600Ati
    Case: Phantek Evo X
    The System works fine except for the issue of going right to boot from a state where its powered off and the UPS is also off. So if I turn the UPS on the system powers up without waiting for me to press the power button. This is not ideal and there is risk of a surge
    - The power button will turn on the computer and turn it off
    - BIOS setting "Restore AC Power Loss" is set to power off
    The issue here is that I can't leave the system powered on, there's a fire risk. I also can't leave the UPS on since I have pets that could step on the power switch on the PC and turn the system on. This has happened before.
    Seems very odd.. however maybe I am missing something.
    ROG Member Array hankieroseman PC Specs
    MotherboardROG CROSSHAIR X670E EXTREME
    ProcessorAMD RYZEN 9 7950X
    Memory (part number)G.SKILL F5-6000J3238G32GX2-TZ5NR
    Graphics Card #1ASUS TUF RTX3090 OC24
    MonitorSAMSUNG ODYSSEY G9-49"
    Storage #1SEAGATE FIRECUDA 530 2TB
    Storage #2SEAGATE FIRECUDA HDD 4TB
    CPU Coolerbe quiet! SILENT LOOP 2 360MM AIO
    Casebe quiet! DARK BASE 900 V.2 Silver
    Power Supplybe quiet! DARK POWER PRO 12 1500W
    Keyboard LOGITECH MX KEYS
    Mouse LOGITECH G703 HERO
    Headset BOSE 700
    Mouse Pad CORSAIR
    Headset/Speakers SOUND BLASTER KATANA V2
    OS WINDOWS 11 PRO
    Network RouterLINKSYS EA9500V2
    Accessory #1 HONEYCOMB ALPHA FLIGHT YOKE
    Accessory #2 HONEYCOMB BRAVO THROTTLE QUADRANT
    Accessory #3 LOGITECH PRO RUDDER PEDALS
    Jun 2022
    9
    I noticed this too by just switching on the PSU.
    TeamROG Moderator Array xeromist PC Specs
    xeromist PC Specs
    Laptop (Model)Intel NUC laptop LAPQC71D
    MotherboardROG Crosshair VIII Dark Hero
    ProcessorAMD 5800X
    Memory (part number)32GB G.Skill Ripjaws V 3600
    Graphics Card #1ROG Strix RTX3090Ti
    Sound CardSound Blaster Z
    MonitorAORUS FV43U
    Storage #1Samsung 970 Pro 512GB
    CPU CoolerCustom loop
    CaseBeQuiet Dark Base Pro 900 V2
    Power SupplyCorsair HX1000
    Keyboard ROG Strix Flare II Animate
    Mouse ROG Chakram X
    Headset Steelseries Arctis Pro Wireless
    Mouse Pad ROG Scabbard
    Headset/Speakers Logitech z906 5.1
    Network RouterpfSense/OPNsense
    xeromist's Avatar
    Jul 2010
    436
    8,666
    ***Thread moved to support area where hopefully ASUS can see it.
    * Support disease research with Folding@Home *
    < < < Click the drop-down above my avatar for my PC specs!
    Moderator Array
    Nov 2022
    42
    215
    Hello, fgentile01.
    Could you help confirm if the issue happens when switching "PSU" or "UPS"?
    May I ask if the default BIOS setting is able to fix the problem?
    Hello, hankieroseman.
    May I ask if your motherboard model is the ROG CROSSHAIR X670E EXTREME and connecting with "UPS"?
    Could you provide the current BIOS version?
    Also, please test with default BIOS settings and switching the Restore AC Power Loss configurations to power off.
    ROG Member Array
    Jun 2020
    13
    Quote Originally Posted by Jiaszzz@ROG View Post
    Hello, fgentile01.
    Thanks for your response! Sorry for my late reply.
    The issue occurs when the UPS is turned on from a power off state. It will cause the motherboard to power on as if the power switch is pressed on the case. The case power switch is correctly installed. The Computer can be shutdown through windows and then turned on by using the case power switch.
    - BIOS version is 0805
    - Tested using default BIOS settings, same result
    - Restore AC Power Loss was set to power off, same result
    It appears my issue was duplicated by another customer. with their board (see thread).
    Moderator Array
    Nov 2022
    42
    215
    Hello, fgentile01.
    To keep the previous state before the AC power loss, go to BIOS>EZ mode > press "F7" to enter Advanced Mode, and set the Restore AC Power Loss to [Last State].*
    Please refer to the ROG CROSSHAIR X670E Series BIOS manual ( English Edition ), page 45, for the setting details.
    https://rog.asus.com/motherboards/ro...lpdesk_manual/
  7. #7
    New ROGer Array
    Feb 2023
    7
    Hello, fgentile01.
    Another person with the same problem on the ROG CROSSHAIR X670E EXTREME.
    As soon as the mains power is switched on the computer starts up first time and without pressing the power button and but all other times when power is left on it boots from the power button and works normally.
    And all connections have been double checked and and even tried a differnt PSU EVGA GQ Series 650w gold and changed to MSI MPG A1000G and the same problem exists.
    Also my bios version is ROG CROSSHAIR X670E EXTREME BIOS 0805 and tried the suggestion Jiaszzz@ROG;884046 and made no difference.
    So i hope asus team look into this bug/issue for us.
  8. #8
    Moderator Array
    Nov 2022
    42
    215
    Hello, Broken.Pc.
    May I ask if you have returned the BIOS to the default value but the issue persists?
    If so, could you please share the following information?
    - the serial numbers of your motherboard and GPU via pm
    - the brand and model name of the CPU, DRAM, and GPU currently installed
    - the OS version and OS build
    I will attempt to look through your configuration to see if there's anything there that could help.
  9. #9
    Moderator Array
    Nov 2022
    42
    215
    Hello, Broken.Pc.
    Could you try set the BIOS>EZ mode > press "F7" to enter Advanced Mode,
    and set the Restore AC Power Loss to [Power off], and press "F10" to save the setting to see if the problem is able to be solved?
  10. #10
    New ROGer Array
    Feb 2023
    7
    Hello, Broken.Pc.
    Just changed the setting you what you asked me to do and still got the same issue sadly.
