HELP: Armoury not detecting devices for syncing AURA
Crasje
Level 12
hi,
A short time ago, my Armoury didn't detect devices in the Aura Sync tab. Then after an update the devices were back. Now I updated again, and they are gone again!!
- whats going on?
- how can I fix this?
I have a Claymore, Spatha, Rog monitor, Rog mobo, Rog Videocard, RGB strip (via mobo), ROG Ryujin Cooling. So, I have quite some lightings to synchronize.
Ps Synchronizing with my Corsair memory is also broken after the updates.
Cooler Master Silent Pro Hybrid 1300W ATX
Asus ROG Maximus Z690 Extreme
Intel Core i9-12.900k
ROG Ryujin 360
Corsair DDR5 Dominator Platinum RGB 2x32GB 5600Mhz
Samsung 980 PRO 2TB M.2 SSD (2x)
Seagate Firecuda 1TB
ROG RTX3080-O10G-Gaming
Monitor 1: ROG STRIX XG349C
Monitor 2: Samsung HDTV T27D590
ROG Claymore
ROG Spatha X
ROG Balteus Qi
Windows 11
xeromist
First thing to try is the Armoury Crate uninstaller tool from the support site, then do a clean install.
I was hoping to prevent this, I would also have to uninstall my corsair (link) software. This is to sync my memory to Aura too.
Sounds like I have to frequently do it, every other update. Not the greatest customer experience.
ROG Ryujin 360
ROG Claymore
ROG Spatha X
ROG Balteus Qi
Windows 11
Andreaz
Last answer will be: Reinstall Windows. I am already sick of it. This software grew to unfunctional bloatware and i now ignore rgb at all... I also will do it in upcoming motherboards. I am bored in unfunctional blinky blinky. I don't care anymore.
Regards,
Andreaz
