Page 1 of 2 1 2 LastLast
Results 1 to 10 of 16
    New ROGer Array
    Jan 2023
    PG48UQ Black screen and HDR issues
    Howdy
    Having some issues with my PG48UQ and wanted to see if it was isolated or not. Have seen a few threads on the 42, but less on the 48.
    Issue 1 - Screen goes black without any message, just black. Doesn't drop input, just black and unresponsive for minutes at a time. Eventually you can use the remote to cycle it off and back on after a few mins. Is this a forced pixel refresh or something, even though it says nothing?
    Issue 2 - Turning HDR on in windows looks washed out and awful. Not sure if I am doing something wrong or not but colours just seem brown? I noticed that RT'ings review of the 42 mentioned something similar.
    Running Firmware V025 so there isn't really anything I can update to.
    People have any ideas or is this just a matter of wait for a Firmware that might fix it? Seems disingenuous to sell something as HDR when it doesn't work.
    Thanks
    New ROGer Array
    Jan 2023
    2
    Quote Originally Posted by Greeny_SA View Post
    Howdy
    Thanks
    To question 1, others have reported it, and I have it as well. Sometimes it just goes black for a few seconds (happens often when I'm gaming, almost never at a desktop). No user fix afaik.
    To question 2, run the "HDR calibration tool" in windows. It helps a lot. I actually bought a calibrator to do this using a sensor, but a good one isn't cheap. The Windows tool is free and works fairly well.
    New ROGer Array
    Jan 2023
    Quote Originally Posted by aphex808 View Post
    Have done a little more digging in the last few days.
    The black thing I timed at exactly 4 hours run time, and then 6 mins of it being locked up and unresponsive. So that has to be pixel refresh, but without a warning, and without it coming back online like normal like if you do it manually. Have to turn off, and on, and wait for screens to juggle and everything to move around. Super annoying.
    HDR Calibration in Windows 10 is pretty useless. I did some playing around and since I have a dual boot of 11, I tried it in there. Low and behold, it seems like HDR is working in my windows 11, but not in 10. Hard to completely verify since I had no luck getting Forza to install on 11 so I could compare, but in Cyberpunk 2077, it certainly seems different. In 10, regardless of game and setting, everything is washed out and muted. Even the menus in 2077 are dull, and when launching, there is a noticeable colour halo around letters in the intro text. None of that is present in 11........ So despite googling, I've found nothing in the direction of a solution to that one
    I'd switch to 11 but after 2 hours of faffing about, I still can't get games to install from the MS store on it. Why must computers be so annoying?
    ROG Enthusiast Array
    Aug 2021
    19
    34
    You need to set the monitor itself to HDR, not just in Windows.
    ROG Guru: White Belt Array
    Dec 2012
    17
    123
    I think these monitors are poorly calibrated with junk drivers. I had a PG329Q and the HDR on it was vibrant. Unfortunately, the monitor had dynamic dimming flicker issues so I returned it for a PG43UQ which has washed-out colour in HDR. I understand that one is IPS with HDR 600 and the other is VA with HDR1000, but they shouldn't be that different.
    New ROGer Array
    Jan 2023
    Quote Originally Posted by Shark007 View Post
    They were both set to HDR in windows 10. So the OS was set to it in Display Settings, and that triggered the screen to go into HDR colour mode. But, regardless of being in the Gaming, Cinema or Custom pre-sets, it was stuck being dull and washed out in all games with HDR enabled. Completely different look when using Windows 11, in there HDR looks like HDR. So after days of being irritated by moving stuff over, have changed OS to that.
    Don't know if it was my Windows 10 being borked or a similar issue to what RTings found.
    Still doesn't fix the forced pixel refresh thing though.
  7. #7
    ROG Guru: White Belt Array J Bish PC Specs
    J Bish PC Specs
    MotherboardCrosshair VIII Formula
    ProcessorAMD Ryzen 5950x
    Memory (part number)64gb KHX3600C18D4
    Graphics Card #1XFX 5600XT Thicc II Pro 6GB Boost
    Graphics Card #2XFX 5600XT Thicc II Pro 6GB Boost
    Sound CardCreative A-E5
    MonitorProArt PA329CV
    Storage #1WD SN850X 1TB
    Storage #2WD Black Sata 6gb
    Keyboard Logitech k750 Solar Wireless
    Mouse Logitech Trackball
    Headset/Speakers Logitech Z906 5.1 1000WT
    OS Windows 11 (All Current)
    Apr 2022
    25
    87
    Could be cable related or video card driver related, I tried windows hdr 1 time and it screwed up my colors,
  8. #8
    New ROGer Array
    Jan 2023
    Quote Originally Posted by J Bish View Post
    It's improved in Windows 11 a lot vs 10 where on my setup, it doesn't work at all. But still looks like SDR content pops more than HDR does, which can't be right.
    I'd need to buy calibration equipment though to have exact numbers which isn't exactly feasible.
  9. #9
    Aug 2021
    19
    34
    They were both set to HDR in windows<snip>
    The monitor itself has a 'mode' setting.
    The monitor needs to set to HDR mode not just Windows set to HDR.
    This setting is on the monitor.
  10. #10
    New ROGer Array
    Jan 2023
    I know.
    HDR was on in Windows and as soon as you enable HDR in windows, the screen goes black for a few seconds as it switches itself to HDR mode. And to double check, I went through every single HDR mode on the screen, while in game to check. Every one of them, in windows 10, looked dull and lifeless where 11 looks ok, but not great. Also this was tested in every HDR mode in game (Cyberpunk 2077 has a few) and on Forza Horizon 5. After HDR calibration in 11 using the new built in tool.
    It's kind of impossible to take photos that show since phone just over exposes everything, but it's night and day.
Tags for this Thread
